Autopilot during rush hour traffic .... a parting of the seas occurs .....
Discussion in 'Model 3' started by LostInSpace, Jun 13, 2018.
  1. RubberToe
    RubberToe Supporting the greater good
    El Lay
    Not as simple a problem as it seems, to handle automatically. So if the "Red Sea" of cars in front of you opens up, how should the car know to NOT accelerate to 70mph if the TACC is set to 70? Well, if the cars on either side are also basically stopped, the car could infer that the just opened up lane in front is a temporary open lane in an otherwise stop and go traffic pattern. Case closed right? Just look at the speed of the traffic in the surrounding lanes and don't accelerate to 70, but something less based on them.
    But then there is the case where you are in an express lane and going 70mph and the next lane over is stop and go. The car would then have to be smart enough to know that in that case it should ignore adjacent lanes when deciding whether you should be going 70 or accelerating to 70.
    RT
  2. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Around here where the only physical barrier between the HOV lane and the stop and go is two yellow painted lines, I still don't want to be going 70 next to them. Someone can (and will) jump in front at any second. If there is a physical barrier, then AP will just see the wall next to you and you are good at 70.
  3. Stretch2727
    Stretch2727 Engineer and Car Nut
    New Jersey, USA
    I agree the max speed should be limited by the operator in this situation, but to me the acceleration in AP is way to aggressive for me in almost every situation. In stop in go or heavy traffic it seem to be either all on or all off with heavy braking. I wish there was a way to adjust the acceleration lower. The braking could also use a little smoothing as well by maybe temporarily allowing less distance to the car in front until the proper gap has open up. I think most people do this as they drive (at least the better ones!) to give a smooth experience and be more efficient.
  4. Az_Rael
    Palmdale, CA
    I liked how the gen 1 Volt did a cruise resume (I didnt have the ACC option). You could resume from 0 miles to freeway speeds and it would do it keeping the "green ball" within the center. So it accelerated in cruise to keep the car in the efficient band. Not very fast, but you can always override with the go pedal without disengaging if you want to move it along.
  5. Jpjpjp
    Jpjpjp Member
    Los Angeles
    How do I do that? Sorry first time Tesla owner so apologies if it’s obvious
  6. AviP
    AviP Member
    New Canaan, CT
    Thanks for posting this. I'm now strongly in the I-dont-want-BetaPilot group. I just don't think it's a mature product.
  7. Stretch2727
    New Jersey, USA
    To adjust the max AP speed, right scroll wheel on the steering wheel, or +/- on the screen on either side of max speed.
  8. JeffK
    JeffK Well-Known Member
    Indianapolis
    It's quite mature and it'll never be 100% perfect. Out of curiosity, what is your benchmark for "mature"?
    Tesla will start posting numbers soon with regards to autopilot statistics, so I'm interested in how you personally will determine that it's ready for you.
  9. chronopc
    chronopc Active Member
    I find it funny how people expect an AI to drive perfectly but are fine with people driving poorly.
  10. Catman20009
    Catman20009 Member
    Washington DC
    I get that stationary objects like parked cars, trees, trashcans on the side of the road (and on the other side of the lane marker) need to be ignored. But I still don't understand why the computers can detect a stationary object like a stopped vehicle or a bicycle crossing the lane ahead, if it's in the same lane makers why wouldn't radar at least see the object blocking the lane?
  11. Jpjpjp
    Jpjpjp Member
    Los Angeles
    I just noticed the +/- today after my post and tried it. Didn’t know the scroll worked too though. Thank you!
  12. teslcls
    teslcls Member
    Pebble Beach, CA
    I've found the spacing control also affects acceleration when seas part. I can usually anticipate that parting whereas software cannot, so attentiveness is important.
    The inability to anticipate certain situations will limit the ultimate utility of self driving cars.
  13. S4WRXTTCS
    S4WRXTTCS Well-Known Member
    Snohomish, WA
    Umm, that's kinda the entire point of having the car do the driving.
    You can correct 100,000+ machines one time. With humans you have to teach them all separately; including the unteachable.
    From this thread it appears that some people are perfectly fine with this behavior as it is exactly how adaptive cruise control work. They're designed to be simple because doing too much can cause issues.
    An example of this was when Tesla added more features to TACC. Like they added a feature where it would automatically slow down for an emergency vehicle on the shoulder. Sounds like a good idea, but then it started slowing down drastically for any vehicle on the shoulder. Then after a bunch of complaints Tesla pulled that behavior.
    I tend to like the idea that TACC remains pretty straight forwards without much intelligence, and AP is where Tesla should add the intelligence.
    So I'm in the camp of the people who believe AP should have more situational awareness to accelerate more conservatively with stopped cars on either side. I don't want to be flying by stopped cars at 70mph.
    I say that as someone who mostly uses TACC, and it's behavior is really predictable so I have no problems with it. I only occasionally have to override it.
  14. jamnmon66
    jamnmon66 Member
    Brighton, CO
    YOU are in control and need to take responsibility to make sure that you're driving safely. AP is just a tool that will do exactly what you tell it to do. YOU had the max speed cranked up so the car did exactly what you told it to do. Take the responsibility to crank down the max speed in this situation. It's pretty simple. AP is NOT self driving, simply a super advanced cruise control.
    • Disagree x 1
  15. Cheburashka
    Cheburashka Active Member
    Los Gatos, CA
    Yes it does.
    Tesla can make a neutral network to turn the damn wipers on but uses basic if/then logic to accelerate the car in traffic.
  16. conman
    conman Active Member
    Melbourne, Australia
    Sounds like my driving style. Maybe the neural network got trained off my driving?
    All joking aside, it'd be nice to have configurable acceleration for the TACC as well, or to look at what you have yours set to already - chill, sport, insane, ludicrous, plaid etc...
  17. diamond.g
    diamond.g Active Member
    Moyock, NC
    Just to be clear are you saying when using AutoSteer that TACC should act differently than when just using TACC? That seems like it would be even more confusing.
  18. diamond.g
    Moyock, NC
    There was a thread in the Autonomy forum that talked about how many cameras Tesla was using for AP functionality. Have they gotten past using the normal and wide angle cameras yet?
  19. Knightshade
    Knightshade Well-Known Member
    NC
    If you mean the AZ driver (hit by a car with a different auto-driving system) it did detect the bicycle, it just wasn't programmed to do anything about it.
    https://nypost.com/2018/05/24/self-driving-uber-saw-arizona-pedestrian-6-seconds-before-hitting-her-feds/
  20. Saghost
    Saghost Well-Known Member
    Delaware
    You already have a feature that adjusts AP to match this. They called it following distance.
    If you have a tight following distance set, the car has to react aggressively, especially on slowing down - there's no room to do anything else, and the current 1 setting seems to be inside of the car's effective reaction time (which is much longer than the theoretical reaction time from the systems installed,) so the car has to brake harder than the car in front.
    On higher settings, the car uses the extra distance to reduce the sharpness of the reaction, driving defensively.
