chronopc
The 90 mph barrier isn't unreasonable. The highest speed limit in the US is 85 mph and in most highways it's 60 mph. I don't think it's a big problem disengaging if you want to do something the car is not designed to do.I don’t see the cognitive dissonance myself. AP is explicitly built so that you can override the speed with the accelerator without having it disengage, ordinarily. The only exception is when you cross the magic speed barrier. I suppose if you imagine that @Peteski went through the thought process of “oh I intend to exceed the AP cutoff limit, should I disengage AP first?” then your criticism would apply, but when I put it that way, it doesn’t really seem very plausible, does it? My one experience with this “feature” certainly didn’t involve the leisure to consider my several options, it was in-the-moment.
This is a case of a user interface element (the accelerator) causing two different behaviors under different circumstances. It’s not a hair-on-fire UI error but I don’t see your “drive it manually or use AP, make up your mind” criticism as being on target.
My use of EAP must just be different from other people so I guess I never ran into this problem. If I want to take control I always disengage first because then I know exactly what the car will do. To me it doesn't make sense to set the car at a certain speed and then not want to go that speed.
