I know that the Model 3 doesn't have an aux input, and that you can't pair a purely A2DP audio device, it must be a phone
I am getting a SiriusXM radio to put in the car and I am looking for the best way to get the audio from it into the Model 3
The XM radio has a built in FM modulator, but I'm not 100% sure I will be able to use it because it's part of the 12v power adapter, and I plan to power it from a USB connector. If the FM modulator is in the plug itself, I'll need to use an external FM modulator.
XM (and others) make "FM Direct" adapters that connect in-line between the radio and the FM antenna. Through Googling I've found threads where folks have found the FM tuner and the antenna connection is not standard, but, there is supposedly maybe an FM antenna amplifier that does have a standard connector on one end...does anyone know if this is truly the case and if so, where this is located?
Or, does anyone know of a bluetooth audio adapter that can be tricked into connecting to the Model 3 as an audio source?
Or, does anyone have experience with a wireless FM modulator that works well in the Model 3? I'm okay with one that has a transmitting antenna to put on the back window near the actual antenna, but all I can find are tiny ones that would be up front near the audio source but I don't think those would work well
Or, does anyone have any tips, tricks, or experience getting an aux audio source into the Model 3 and want to share?
