So I learned my lesson from my first track day lesson last year but got to pay the price today. Had to replace both front Sport 4S's in my P3D because the shoulders got ripped apart from autocross, wires showing in multiple places.
So I'm in the process of setting up to use RE71Rs for the track going forwards. is that sufficient or is there something else I should be doing. e.g. letting the car cool down more, one issue with the autocross was they weren't checking groups so we essentially did it continuously for ~3 hours morning and another 3 hours afternoon? or dropping tire pressure, I was probably running something like 45 psi hot (as measured by TPMS after a lap) that day. Do I really need to go all the way to getting some camber adjustment with a suspension change?
Hopefully switching to this "real" track tire will help!
I think you've gotten a lot of good advice, but my experience on the skidpad suggests that the 4S is really greasy at 40+ lbs, esp. at 45 and that they have a bit more grip 37-39 lbs - and less greasy breakaway for sure. If you had -1 to -1.5 camber at least, and lower pressure than 45 lbs, you might have avoided the worst of chunking, but as others have pointed out, this tire isn't really built for hot lap after hot lap. For sure, from everything hard core track guys on the forum have said, the RE71s look like the way to go, but aren't fun on trips or on the street in general. Good to get separate wheels and tires for track and street - expensive, but then again, tracking a car isn't a cheap hobby!
