You are missing the fact that not everything in life is about money or resale value. Sounds like the only thing you are focused on (with your responses here in this thread).Please all of you that think you should charge your car from 0 to 30% every day for everyday use. Please write me a for sale listing for your car on how you are going to show me that added value to the car about your charging characteristics.
Not after 10 years but after 3 years when you sell the car because you want a different model and you're trying to claim that your battery was better taken care of, but it still shows the same range as someone that charge to 90% every day.
FUDthey get fed this stuff about leaving their car at 5%. Charging it only to 30%
Lowest charging setting is 50%So I write this for those people that are coming here. Thinking about buying a Tesla and then they get fed this stuff about leaving their car at 5%. Charging it only to 30%.
You're putting your best out there.@AAKEE
Imagine someone said to you that if you change the oil in your ice car every thousand miles, your car will last approximately 6 months longer.
Or
One must fill gas tank and keep it at 25% or higher or it does some type of damage, but maybe not quantifiable. Don't get the dregs of the bottom.
If these thought processes really were true or caught on. Start building the horse barns and start making saddles. People wouldn't stand for it.
Yes statistically it might be true. If you changed your oil more frequently, you'd have less particles in the oil which would make your engine last longer. If you don't get the bottom of the tank, we're all the impurities are maybe your fuel injectors last 6 months longer.
Maybe look at it from a practical application standpoint rather than the 3% of the drivers that think like you do.
Realize that you have a bigger audience than you realize and that your forum posts reflect that you are considered the expert.
My question is it really applicable in modern world for mass EV adoption.
Sure, a car that charges to 100% and is parked 110° garage in Arizona is probably going to have more degradation than the one that charges to 100% inside of a garage in Maine that is 40° after a couple years.
The thing is that both users just have to use their car because they can't just recreate their house to charge in a cool environment and have an envelope around their car in coolness. They have to live in Arizona.
@zoomer0056 surely you can do better. Discussion is always better. Isn't that why this is a forum of ideas and thoughts? I mean come on. A guy that has done over 50 deliveries with strangers and helping build sustainable transportation is a FUD spreader.
Edit add: There are other threads where you basically say charging to even lower than 30% is not a bad thing and you can just do that. My question is is that really a suggestion worth keeping letting the car sit at zero and it's statistically it's not bad and things like that. Think it creates more confusion in the guest not the owner.
Again adoption is more important than the 3% of people that think like you. Clean air or a babied battery for the elite as adoption cratered because people don't understand and don't have PHD's?
He seems to have a RWD Model 3 from 2018 and is probably quoting 291 miles out of the original 310 (94%). Which is 68kWh, down from 77.8kWh, 12.5%.Model 3?
That’s a lot of miles, which vehicle (I could look through posts…). I assume it is a Model 3 RWD? Showing 276 miles or so?Battery university can't explain why I have 11% degradation and someone else has 20%
I prefer to think of it as information but I guess YMMV.I am also free to say what I believe is disinformation.
For me it is not about how long it lasts, it is utility. I want to be able to make long legs between Superchargers. I’m already in a situation where e.g. I have to stop at Inyokern and can’t go from Bishop to Hesperia in most cases. I don’t want to make that worse.your car will last approximately 6 months longer.
People will have heard about capacity loss on EVs. It’s something they will want to understand.Again adoption is more important than the 3% of people that think like you. Clean air or a babied battery for the elite as adoption cratered because people don't understand and don't have PHD's?
You should look through my previous posts.He seems to have a RWD Model 3 from 2018 and is probably quoting 291 miles out of the original 310 (94%). Which is 68kWh, down from 77.8kWh, 12.5%.
Minimizing capacity loss enables longer stretches between Superchargers for a longer portion of the car life.
Is it a huge difference? No. Does it matter? Yes.
Does using @AAKEE ‘s suggestions work? The available evidence suggests yes, so far.
Personally, it’s been very freeing for me to realize that it can be slowed way down with zero impact on my ability to charge the car to 100%. The two are completely compatible in my case.
I actually think allaying people’s fears about capacity loss with data-driven discussion actually helps EV adoption.
Remember that very little of @AAKEE ’s advice limits the charging of the car, for a typical user. It’s for the most part a recommendation of how to store the battery, not how to use it. You can charge it to 90% or even 100% pretty much as much as you want! Just then drive it, and don’t leave it there.
This is helpful to prospective owners, and it’s not complicated to grasp. It does not require a detailed knowledge of batteries and is as simple as understanding that one should change ICE oil at regular intervals.
Following the advice has also helped get me in the habit of always plugging in at home. something I was sometimes lax about before, and is something that most EV owners should be in the habit of doing (it’s the best part of EV ownership!).
Now, this is very interesting to me! I would love to add a few predictions based on science and knowledge to my charts and see how close/far my battery will be.But I can explain and probably even predict the most probable degradation that your car has.
This is what I need:
What we should check it against is a energy screen calc, as it is commung straight from the BMS Capacity numbers.
Where do you get the "lifetime average consumption" number from?Now, this is very interesting to me! I would love to add a few predictions based on science and knowledge to my charts and see how close/far my battery will be.
You tell me what Tesla you have. Model/year and: MYLR 2023
-Location/average temp: Killington, Vermont 05751. Over the course of the year, the temperature typically varies from 12°F to 81°F and is rarely below -6°F or above 89°F.
-Manufacturing month or purchase month: DOB 2/16/2023 and pick up 3/3/23
-Do you have a garage or is it parked outside? Garage
-Charging level. Daily 50% and I keep it plugged in. Charge for trip varies from 70-90% with couple trips per month typically.
-What SOC (charging level) do you have after a normal day. 42-46%
-When do you charge? Daily (?), at what time does it start. Daily. I just keep the car plugged mostly all the time. When planning on the trip than I use schedule departure.
-Odo reading. 3845
-lifetime average consumption. 308Wh/mi
I also took a few pics.
My intent is not to hector people into buying an EV. There is no need to convince fence sitters!!! We are not trying to “make sales!” There is clearly no need to!You should look through my previous posts.
2017 model S 250k with 11%
2017 model 3 160k with 8%
Again all I am saying is put all the charging suggestions to a fence sitter on EV's. One won't make the sale.
Wait I have a car that can go 300 miles and you want me to charge to 50% I don't understand says the new person to an EV. Why? Oh because it's good for the battery. Your going to keep the car right? For like 3 years.....Why should I care?
Can't they make the cars so they can go 300 miles? Sure but charging like that high that often leads to faster degradation. What's degradation? Oh it's the amount of battery use you lose each year because of the calendar and your usage. So I want a car that gets a junky battery? Can't I charge it like my cellphone? Oh no. See what happens to your phone? You don't want that do you?
Screw that I am buying another GMC Yukon Denali.
Or imagine that lithium batteries might start to behave unpredictable and loose capacity fast at about 20% degradation (20% is the industry standard for end-of-life.@AAKEE
My high was 317. I am at 296. The earliest 3's were messed around with quite a bit on reserve as you know.My intent is not to hector people into buying an EV. There is no need to convince fence sitters!!! We are not trying to “make sales!” There is clearly no need to!
People should buy EVs because they work well for their needs.
All we can do is provide the facts, not hide them, as suggested.
You are suggesting that well informed consumers don’t know that EVs lose capacity…which is just not true. I want to inform them that this natural wear can be mitigated and at the same has nearly zero impact on how most owners use the car (it only impacts storage).
Regarding your Model 3: is 8% 8% of 310 miles Model 3 RWD?
(If so that is 14% or so as detailed above.)
For Model S I don’t know how this was handled. Looking at rated mile loss is not a reliable method to in a general sense - it’s good, but you need more information. Certainly rated miles work similarly on older vehicles but the starting point and how that was dealt with might be different.
My car - TripsWhere do you get the "lifetime average consumption" number from?
-Odo reading. 3845
Awesome - thank you! Would you mind sharing how you did above magic and the math behind it?The 82kWh batt varies some during the EPA tests, I took the starting number from the 2023 EPA MYLR Application (end SOC Watt hours, 80.7kWh).
Your low SOC might set you off a little.
I found the annual average temperature for Killington to be about 5C so not that warm. You still had the first halv year covering the hot season so your battery should be be slightly before a simple annual average.
If I do a calc on a higher cell temp/ambient for having the most of the cars life in warmer than your average it says 78.3 kWh.
So you’re on the plan dedpite seeing just a little lower capacity than the calc.
The long term is more interresting, of course.
After 60 months and 10 times the miles you have today you should be looking to this
From @AlanSubie4Life’s charging constant thats 69.3 kWh, so 11% capacity loss from the ”full pack when new” (77.8 kWh) (and also some of the EPA tests).My high was 317. I am at 296. The earliest 3's were messed around with quite a bit on reserve as you know.
I am very interested in the tracking, and have attributed my S to something similar to what @AAKEE says. However I drove 72,000 miles last year, and 65,000 the year before.
I charge to 90 or more, but the time spent there is negligible because of how much I drive.
