So there is NO way to know if this is installed on your car?
-Randy
The boot loader will expose itself over CAN when performing UDS commands (I.e. software updates). But no, there is no easy way to tell.
-Randy
I wonder if you really wanted new firmware faster if anyone can just come lurk around the service center outside and get the update immediately?
I should have asked what the update was for / resolves. It kind of feels like Tesla has been a bit quiet about this update.
This has me concerned because I am 400 miles and 3 1/2 hours drive from a service center. Either I make a seven-hour drive plus the time it takes them to get the car in and work on it, or the car gets flat-bedded to Seattle and back, and there could be days delay in scheduling the return trip. Grump!
I am impressed that you can do 400 miles in 3.5 hours!
Oops! I was using Google maps, which says the service center is 300 miles away, or 4 1/2 hours. I typed the numbers the wrong way around. Thanks for catching that.![]()
Aww... It was more fun believing you could do 400 miles in 3.5 hours. That would be AH-MAZING!![]()
??? I routinely set the AP to 20 over the posted limits on CA freeways. At 5 over, you would probably get rear ended in the first mile! Has anyone else seen a max of 5 over the posted limit?I think the car is capable of driving 114 mph. I certainly could not drive it at that speed, but maybe a race-car driver could. But you can't use AP faster than 5 mph over the posted limit. And I'm far too lazy to drive the car myself when it can do it for me.(When set to km it will go 10 km over the posted limit. So in Canada I could go 6 mph over the limit in AP.)
It gives me a message saying that autosteer speed is limited to X, where X is 10 km/hr (if I'm using km) or 5 mph (if I'm using miles) over whatever it thinks the posted limit is. When I enter a space with a lower limit, it slows down, and gives me that message, and if I try to set a higher speed it won't go higher, and it gives me that message. I'm on 2018.28.1.
Is there maybe a setting you can change to raise that amount?
On many roads, Tesla limits Autosteer to 5 mph over the speed limit (which is especially annoying when they have the wrong speed limit on the screen), however, on "freeways and highways where access is limited by entry and exit ramps", it does not have that limit (at which point, I believe it is limited to 90 mph by TACC).
Also, auto lane change only works on those same restricted-access roads.
I had wondered why auto lane change wasn't working. I knew it didn't work on surface streets. But it also wasn't working on the Trans-Canada.
Anyway, isn’t this thread supposed to be about the BMS update?
It seems my original skepticism about their claim that the BMS was already updated was well founded. When I did bring it in for the dent removal, they said they'd also be updating the BMS firmware.I need to bring my Model 3 in for some paintless dent removal (to remove a dent caused by a wonky door motor in my Model X) and I inquired about having the BMS update done at the same time. According to the SC, the Model 3 already has the update. Since it was a 4/23 delivery (VIN 128XX) that's never been in for service, I assume they're either doing the update OTA or they're simply mistaken.
