Best Aggressive Wheel Offsets?
I went with 20x10.5 et40 275/40/20 all around. I wanted to keep the same concavity all around. Bagged btw.
ProjektY, where did you get that front bumper lip and those LED Fogs??? Those both look really sharp. I really like your entire setup to be honest! Only thing that doesn't make sense is your listing of the offsets. You have all kinds of different offsets listed. Could you please confirm your offsets and tire sizes for us?
Per requests to OP. 15mm spacers F/R on 10.5 et40. Final et of 25 all around. Pretty wide, definitely will rub and need to run negative camber.
Any more pics to show how much poke you have on the +16 9.5s? How come you went lower offsets on the front but not back vs the AGs?
What size tires are you running? Is it lowered or factory suspension?
The AG were my first set, and I spec'd those to fit flush on the Y, I had them pushed out 10mm all around vs the OEM Performance wheels. But I like a more aggressive fitment so I used 5mm spacers all around.
Car is lowered on UP Moderate springs with 255/275 OEM Pirelli P Zero tires
I only got rear camber arms so the front has more camber than the rear, about 2 degrees in front, so they need to be pushed out a bit more
The ADV offsets were preset, Im using the BMW M5 fitment and had the bolt pattern custom machined, but offsets worked out perfect.
Any side pictures with your ADV's? Those look super sharp! What offsets are you running now with the ADV's? Also, what brand of fogs and bumper lip are those? I haven't seen anyone really running either, and I love both!
Thanks!
+16/32
The fogs are from luckeasy on aliexpress. Lip is from Changzhou Maofa Vehicle Accessories on alibaba
Here’s a side pic of the ADV
Question for you guys - admittedly, offsets confuse me. I am looking to order Rohana RFX11's for my MYP. Could I run a square 20x10 +40? I see Dr.Will is running a square 20x10 setup but with a lower offset - which makes me curious of how the +40 would work. Suspension will remain stock for the time being.
Big thanks if anyone can help me out here.
