Best Aggressive Wheel Offsets?
Front 20 x 9.5J +45 - Rear 20 x 10.5J +25
Got my new setup mounted on my MYP. 20x10.5 ET35 square with 275/40/20 Continental DWS 06 Plus square. I would have preferred a slightly more aggressive offset, but the combination of Fitment, style, weight, and cost were all factors. This setup saves me 15lbs per corner over the stock MYP set.
Do you have a pic of the front? does it poke out?
How about running 295/40/20 on 20x10 ET30, rears stock LR height. I'm mainly concerned about the rear fender & tire poke. Do you guys think it would fit well without any camber adjustment? The wife will also be driving the MYLR, so maximum rim protection is needed.
That will fit fine in terms of offset and such. Tire is pretty tall compared to a stock one, but it will also fit fine with zero issues.
What size front tire are you planning to run?
Looking to run a 20x9.5 et30 with 275/40 that the fronts I know will clear. Just worried about the 295 sticking out and rubbing on the plastic fender during compression.
