Borgholio
Speaking from experience in my Prius, the best gas mileage comes from using a combination of techniques. First, I don't use Eco mode anymore. I used to when I first got it, since it forces you to accelerate slower and lowers the power usage of the A/C. But in truth, setting the A/C temp wisely (a few degrees below outside temp) will keep you cool and use less energy than setting it to frigid in Eco mode. Accelerating slowly is also (counter intuitively) worse for efficiency. It's actually more efficient to use normal (or even power) modes to accelerate briskly and get to your cruising speed quicker. You don't need to floor it, but don't feather it.
Using cruise control is a great idea when terrain is flat, but it's a good idea to disengage and accelerate slightly on the downhill, then re-engage cruise as you begin to decelerate on the uphill portion. That way you can make use of a gravity assist to save fuel, and the cruise control doesn't go crazy when you hit bottom because it couldn't predict the coming uphill.
So with the Model 3, I would expect the same to be true. Use moderate acceleration to get to your cruising speed and then use autopilot to stay there. If you encounter a hill, accelerate down and then engage autopilot as you start to lose momentum on the uphill. Set your A/C to a few degrees below ambient and just keep it to where you are comfortable, no lower than you need.
