“In the world of batteries, the 0% SOC is defined as the stop discharge (cut off) voltage, 2.5V in many cases for lithium ion like Tesla NCA.”
You’re doing it again, now using the “0% SOC” instead of a fully discharged voltage level of zero. SOC is a calculated value based on the full charge and the battery manufacturers acceptable discharge floor. It’s still an artificial number. That floor is still your 4.5-5% residual capacity.
I say a battery discharged to zero remaining capacity, having a 0 volt output will be damaged. You say a battery discharged to a residual charge of 4.5-5% and a voltage of 2.5V won’t be damaged. I have no problem with that. The electrolytes in your 5% charged battery are not exhausted. I doubt you disagree with my point that a battery discharged to the point it produces no voltage will likely be damaged.
if OK with you, let’s agree on the above and put this dog to bed.
