Thanks. I asked the same question on its Amazon site and got a half-dozen similar answers - more or less along the lines of "it creates its own WiFi". Of course, none of them reported the product having any glitches at all.....
View attachment 44432I just installed a DR550GW-2CH with the little Power Magic Pro UPS. Everything works fine although I am waiting for a shielded cable before I add the rear camera. The WIFI connection drops every few minutes and is choppy but that doesn't matter much to me. If your WIFI fails to work try upgrading the firmware to the latest version. I used continuous power and ground from the unused connector behind the microphone grille and switched power from the yellow wire with the green (or gray) stripe in the rear view mirror connector. I had to toss the little box the UPS came in due to space limitations and mount the circuit board directly to the inside surface of the microphone grille with rubber standoffs. The GPS locked on after about 45 minutes of driving and is accurate. The frame rate appears to slow a bit when the scene is complicated but the Blackvue viewer works well and the micro SD card accepts any changes made through the viewer software.
I have absolutely no problem receiving GPS immediately. But I mounted the Blackvue camera a bit to the right of the center housing.
The Power Magic box also prevents draining the 12V battery if the car is parked for a long period.
I have a question on the re-writing feature, how do you enable this?I've had my BlackVue DR500GW-HD for a few years now. when I first got it everything worked. last year I noticed that I no longer had GPS. firmware updates didn't help with that. about 3 months ago my video files stopped deleting/overwriting the oldest files with the new video files. I can still connect via Wi-Fi and watch live video but it appears that's all I can do.
If I let my cameras (DR650GW-2CH 1080p) run non stop, for 24 Hrs, the card (64 Gig), fills up and the cameras stop recording. If I press the format button on the front camera, it erases the files on the card and it causes the error "please check card". I have to remove the card, place it in my PC and copy the BlackVue folder/files back onto the SD card before the camera sees the card. If I format the card using the PC program, it also removes ALL files and I have to put back the BlackVue directory.
v.07.16 camera firmware, back onto the SD card.
Everything works but the GPS and the over write feature.
Where did you find the new firmware? I didn't see it on the blackvue website. I just installed a DR550 and everything works for both cameras but the time is off by a few hours.
I had the same date and time problem of my DR650GW-2CH dash cam. This is an easy fix.
Just slap the micro-SD card into the computer, search for the folders called Record and System. Empty both folders. Insert card back in the cam and it'll fix you problem. Make sure you also update to the correct time zone.
