PtG62901
Nothing but good news for Tesla. GM says their market is real, and they get to compete with GM, the market leader in bullet points and mediocre cars.
Wow, 350! Pretty small battery space, but I hope so. Go Tesla, go EV marketplace!During the Model 3 reveal, Elon was very careful to say that the base model would have a minimum of 215 miles range.
I think the Model 3 will be competitive, and with a smaller battery as well.
I'm still holding out hope for 350-400 mile range option at the high end.
Pretty impressive number and it appears that you will actually be able to buy the vehicle this year.
gm also said the price is under review. i expect them to at least match the price of the m3. Any competition is good for us and the m3 now needs to equal the bolts range.Bolt is still $2500 more expensive (unless that changes now) and you will have to pay more for the DC charging option. As we know Tesla already has cars with much bigger range than Bolt (and more expensive). If we compare range we have to compare the price also.
Huge kudos to GM and LG on this one. I hope and expect that this car will sell well above their expectations. Tesla has created quite a halo around electric cars and the Bolt is the first one that can probably really benefit from that.
I also expect that the base model 3 will exceed the Bolt's range. The car is similar in size & weight but has a much lower drag coefficient. And physics is physics.
The 50kw charging limit is a bit of a disappointment. That will limit the car to being mostly a local travel / second car. But at that price, that's probably ok.
Yep, if you are near one of the "select dealers". Which translate as "CARB state dealers". Non-CARB'ers will have to wait till sometime next year. Luckily I'm in MD.
I've been really concerned that 215 is not enough for my own circumstances. I have one frequent day trip that is about 260 and the only supercharger will surely be very busy as Model 3's pop up. I'm hoping 300+ will be available for a reasonable upcharge.
On a separate issue, it has occurred to me that these early Teslas may face a bleak resale future if battery ranges rapidly increase.If I leased or flipped my car purchases every three or four years, that might not matter much. But I buy and hold each car ten years or more.
Mass?MS P100D: 100 kWh battery / 315 mi = .317 kWh/mi
MS 90D: 90 kWh battery / 294 mi = .306 kWh/mi
MS 75: 75 kWh battery / 259 mi = .290 kWh/mi
MS 60: 60 kWh battery / 218 mi = .275 kWh/mi
Bolt: 60 kWh battery / 238 mi = .252 kWh/mi
Why is the bolt battery more efficient? The Cd of the MS is better so aerodynamics can't be the reason.
Much lower weight due to much smaller size of the Bolt.Why is the bolt battery more efficient? The Cd of the MS is better so aerodynamics can't be the reason.
The real question is how is Bolt that much more efficient than similarly shaped i3?
We were to believe the i3 is some engineering marvel, superoptimized and what not... and then comes the GM and beats it to the ground with no fancy shmancy carbon-fiber thermo-plastic materials, but with plane old metal.
Bolt is no threat for M3, but is an endgame for i3, Leaf and similar punishment cars.
