steilkurve
Well, after reading through all this and discovering the trailer we want has a loaded weight that will likely exceed(or get uncomfortably close) to the 500lb tongue/hitch weight rating of the Bosal, we've ordered the Draw-tite as then we have a 750lb tongue weight rating which gives us the breathing room we need. Feels wrong to swap this out on a 1 year old car, but we didn't feel like rolling the dice.
Edit: We also plan to use a weight distributing hitch since the worries about the Bosal hitch being damaged have ceased, and although nobody seems to have a proper answer, when we are setting it up we will set to standard, then engage jack mode to ensure we aren't fighting the air suspension.
Based on what I've read this seems to be the best scenario. Our trailer is only 4,500lbs fully loaded, but with the tongue weight and the trailer place really wanting us to use a WD hitch I think this is the best solution. That or order a Cybertruck.![]()
Good call. Went through that exact same thought process last year. Before buying, we rented an Airstream Sport and towed it with the Bosal receiver. Worked fine but when we decided to buy an Airstream Bambi with a tongue weight closer to the X’s limit, we ditched the Bosal and had a DrawTite installed. Towed on the ball until the season ended. Went fine but want more safety. So we just purchased a WeighSafe True Tow WD hitch. Should get and install it in the coming week.
