I finally got my Martian 19x8.5" wheels to replace my 21s. Today, I had the Bridgestone Quiettrack 255/45-19 104V tires installed. Is it just me, or do these tires suck? I bought them for their quiet ride and low rolling resistance. I accepted that the wet handling would suffer, as per reviews. These tires are louder at every speed and on every surface compared to the 21s. Annoyingly loud. That's the very first thing I noticed. So I thought, maybe they're quiet on the freeway. Nope. Not only are they loud in general, but at certain times at around 65 mph you get a whine with them. So I thought, "Hey, at least I'll get an improvement in range." Nope. How about a range penalty. I drove a loop that I've measured efficiency on multiple times. Traffic was heavier than I'd accept for a completely reliable test, and the first half of the loop the road is damp. The first should actually increase range as I was averaging 62 instead of the 65 I use to test range on this loop. Plus, I was behind a van which would normally increase range due to the drafting effect. On this loop I've averaged anywhere from about 261 wh/mi to 278 wh/mi. with the Bridgestones I averaged 290 wh/mi. My worst run ever. I'll run it again in the morning when it should be dry and light traffic, but still.
As the reviews told, wet traction was significantly worse than with the stock 21s. I expected that. It was acceptable I think if you will be running winter tires for the winter. For an all year tire I'd have to say absolutely not. The grip wasn't horrible, and it was predictable with no surprises, but not something I'd accept for winter driving. The tire is rated "Very Good" for rolling resistance, so I thought it would be worth the trade off. Like I said, I'll run my test loop in the morning, but if I don't see a max of 250 wh/mi, they're going back to Bridgestone.
Has anyone else tried these? Do I just need to break them in for a few days? Or are they as bad as what I'm seeing now?
