Fixed Mine! Just needed a somewhat old fashioned $12 tool - a brake spring plier used to attach springs on drum brakes.
There is even a little hole already in a convenient place to catch the pointy end of the tool. The hook end fits perfectly onto the spring.
It was a bit of grunt. Definitely use safety glasses and heavy gloves in case the spring flies off (and work away from your Tesla...)
I'm not the strongest person. If you have been to the gym in the last year, you ought to be able to do this.
I'm convinced if the double ended hook was bent around a little further then none of us would have this problem. The wiper arm has a stop to limit travel, but it barely seems to engage - if that was a little longer, I think that also would also prevent this problem.
View attachment 218853 View attachment 218854
hey how did you get the arm off. I undid the bolt on the top but the arm just doesn't lift off
