I do know that the most obnoxious rattle in the car was somehow introduced after the windshield was replaced. Looking at the parts schematics the dashboard is a single piece that then has the vents, trim, glovebox and other parts installed onto it.
When I took the lead tech on the test drive he was able to get the buzzing to stop by pushing down on the dashboard. He claimed the "dash pad" needed replacement but my research shows that there is no dash pad, there is just a single monolithic structure that the other pieces screw or snap into.
The tech who addressed this problem didn't say anything about replacing the dash pad (at the time I didn't know the dashboard was one part) instead he said he removed the vents, the front trim piece, checked fasteners, etc.
And I found some felt strips on the floor of the car so I imagine he tried to felt line some of these parts to make them more resistant to buzzing causing noise.
It is definitely much better than it had been but the problem is still there, and does not go away when I push on things so it's possible at this point that the problem is between the dash structure and the car's body and only shows up in certain situations.
I will have to do more research on what could be causing it. Replacing the entire dashboard may or may not fix it, plus of course Tesla's reputation for introducing new problems when they "fix" things.
Le Sigh.
Yep. The same type of buzz can be heard from the headliner all around. It’s a lot softer and less annoying, but it points to the respective material having been trimmed such that it rubs a bit against the body.
