Currently we use about 4-5 kw per day. That means I charge for about 2 hours at home before hitting the 8.8 limit.
Is this really measured on a daily basis, or per billing cycle (monthly)? It'd be a pain to have to track electricity use on a daily basis.
In any event, 8.8kWh per day works out to 264kWh in a month, which isn't much. I've just checked my own TeslaFi data, and for the past several months, my car has been using 170-210kWh per month in home charging, plus more in away-from-home charging (Supercharging on road trips and the occasional Level 2 charge at local public EVSEs).
Looked at another way, the Model 3's EPA fuel economy figure is 116 MPGe, or 29 kWh/100 miles (290 Wh/mile). If you were to drive 1,000 miles in a month (about average for the US), you'd use 290 kWh -- just over the limit to get your lowest electricity rate. Of course, if you do a significant amount of charging away from home, you might still be able to keep your home use low enough to not incur additional charges.
Another detail to consider: If you exceed your 264kWh/month, does the rate go up for
all your use for the month, or just for your usage that exceeds the 264kWh? If the latter, then using, say, 300kWh in a month won't really be that big a deal -- you'll be paying an extra $0.06/kWh on just 36kWh, or $2.16. If the rate goes up for
all of it, though, that'll be an extra $18.00. If the excess is billed on a daily basis, then the computations get trickier. Even if your non-EV electricity use brought you exactly to the limit, a Tesla being charged enough to drive 1,000 miles would cost you an extra $17.40/month for going over the limit. That's pretty much the limit for what exceeding your limit for your car will cost, assuming average US driving habits and 100% home charging -- and also assuming that you still pay $0.22/kWh for your usage below the limit. (The total cost for charging 290kWh at $0.28/kWh is $81.20.)
I'm trying to ultimately figure out how much I can charge at home without going into the higher tier. I can charge at work for free, but typically only get about 9 kw of charge, and only drive to the office 3 days a week.
This sounds like Level 1 charging (off a 120v outlet). If your office has a Level 2 EVSE, then you ought to be charging at about 6kW, for about 48kWh of charge during an 8-hour work day. You may want to check
PlugShare to see if there's public Level 2 charging available near your work, or near other places you frequent, for that matter. Level 2 EVSEs are often situated near parks, malls, movie theaters, and so on. Some of these are free, but some of them cost money.
This gets me every time. I don't understand the distinction.
1.44 kWh per hour expands to "1.44 kilowatt hour per hour"?
Others have posted explanations, but here's another way to look at it: kW is a flow rate, like gallons/minute; kWh is a total quantity, like gallons. The time unit ("h" for "hour") gets used as a multiplier in electricity, but it's a divisor in most units with which we're familiar. If you're not used to electrical units, this seems backwards and counter-intuitive, but mathematically, both approaches are equally valid.
