Where I live we pay about 30 cents, make sure you read that correctly 30 cents not .30 cents
He's from California, so this is clearly a typo on the OPs part.
What would the kwh usage be from a 120v outlet?
Probably what you should really ask is how much it will cost you per rated mile (this is different than driven miles, of course)....however...
At 12A, it will be 12A*120V = 1440W (power), so in 1 hour that would be 1.44kWh (energy).
Plot of charging efficiency vs. input power
So, you need to translate this to a per rated mile (rmi) number. I'll assume you have an AWD/Performance. There are a lot of ways to do this, and the way below isn't really the simplest, but I wanted to answer it in the context of your question.
You'll be getting something like 70% charging efficiency based on above plot. So that means:
kW (battery) / kW (wall) = 0.70 (Same for the kWh ratio FWIW).
kW (battery) = 0.7*1440W = 1.008kW This is what you'll get (power, not energy) into the battery for a 12A/120V outlet.
For an AWD, it's 245Wh/rmi => 1.008kW / 0.245kWh/rmi = 4.11 rmi/hr
Your electric expense for this, per hour, is 1440W *$0.22/kWh = 31.7 cents/hr
So this is 31.7cents/hr / 4.11rmi/hr = 7.7cents/rmi
Also of interest, 1.44kWh/4.11rmi = 35kWh/100mi (but this isn't quite fair to compare to the 29kWh/100mi EPA number, for subtle reasons you have to multiply by ~76/78). But in any case the "penalty" for 120V charging is pretty clear.
Notably, you'll likely end up using considerably more rmi (rated miles) than miles you drive. But this is a starting point. The point is your costs per driven mile will almost certainly be higher than this.
You can use the stats app to calculate charging and kwh usage.
Note that this Stats report does NOT report the kWh from the wall. You have an LR RWD...I could tell without looking at your signature...because 19.37kWh/83rmi = 233Wh/rmi which is the approximate charging constant for the LR RWD - but this is AFTER the AC-DC converter and it ONLY counts energy added to the battery...
If you want to monitor your actual charging costs you can hack it by inflating your per kWh cost in the Stats app, if you always charge from the same place, by whatever the efficiency ratio is.
