The load calc sounds high to me given your appliances. Was it a standard or alternative load calc? Can you post a copy?
BTW, unless they actually went out to your house and read labels off of your appliances, it wasn't a real load calc.
Yes it was. i havd pictures of all appliance labels so thos were used.
Calculation was done according to the standard method.
2000 Sq feet x 3Va = 6000 VA
2 small appliace circuits (kitchen ) 2 x 1500 VA = 3000 VA
2 Laundry branches 2x 1500 VA = 3000 VA
since my wahser and dryer fall in the above branches no additional penalty for their loads.
Yields : 12000 VA. first 3000VA is at 100% , remainder at 45%
so 3000 + ((12000-3000)*0.35) = 6150VA base load
Now come the big kickers..
Dishwasher : 960 VA
Disposer : 900 VA
since less than 4 units they count as 100% : 1860VA
Range : 6300VA
airco : 5856 VA
Motorload of airco ( 25% of above ) 1464
total demand :
6150 base load + 1860 fixed appliances + 6300 Range + (5856+1464) HVAC = 21630 VA.
divide by 240 and you get ... 90.1 AMP on a 110 Amp cable with 100 AMp circuit ( cable is 1 AWG Alcan Stabiloy rated at 110 AMP. I even had that information )
Since an electric car is considered a permanent load it is counted at 100% . so 240 volt 30 amp circuit = 30 AMP continuous. I only have 10amp reserve.
So the end solution was easy. since i have an existing 30 AMp 240 volt breaker : throw out the oven and switch to a gas range ( i have gas pipe in place. my burners are gas, only the oven is electric (wall oven) Oven is mounted under burners. Modification is very simple. i will get a slide-in gas range. costs 1400$. no problemo. My oven had problems anyway (control would lock up) and i prefer a gas oven for baking. Besides i only use that oven 2 or 3 times a year. I'd rather drive a Tesla every day ...
The building inspectors told me that , basically , a 100 AMP feed for a large condo (2000 SQ ft) is rated for 2 permanent loads. one HVA and either a range or a dryer. That's it.
A friend of mine who has a house is in the same situation. he want to get a leaf. with tis 100 AMP service it could not be done. they upgraded to 125 AMP service ( luckily their main cable could carry that... in my case it wouldn't. )
And yes, from a pure technical perspective i'd put the caron 40 AMP since it will be charging at noght when i dont run ovens or dryers or washers or dishwashers.. But that is not the point.
Since this is an installation in common property the HOA demands a PERMIT. Permit means : signoff by inspector. Inspectors like calculating ....
By switching the oven to gas there is no calcualting. We are not installing new breakers so there is no load change. So according to 'the book' nothing is required. whatever you do behind the breakers is of no interest.
