Can I use the Tesla mobile charger to charge my other cars that are not Tesla? I see that you can buy an adapter to convert to j1772.
For something like that, I don't know that it's worth trying to share the Tesla plug. The i3 is such a small battery, that it can generally get by with its own charging cable that runs from a 120V outlet anyway. I was thinking of that kind of thing if we were to get a second short range EV, and was just planning to get its own 120V cord to plug in on the other side of the garage.I was thinking of going the Tap route but may just get a regular charger because the i3 would be outside the garage and there's no way to secure the Tap. I wish there was a way to secure the Tap to the Tesla connector.
The Leaf has an option to lock the charge port. So the adapter can’t be removed from the leaf and stolen. Not sure if the I3 has anything similar?I've been mulling over the idea of getting our teen a used i3 s. And eventually the topic of how to charge it comes up.
I'm never going back to 120v charging... 3mi/hr and the efficiency losses. Do the math, say for a 60 something miles top off, that's over 12 hours vs just over 3 hours using 120v vs 240v. The numbers are from the evcompare site.For something like that, I don't know that it's worth trying to share the Tesla plug. The i3 is such a small battery, that it can generally get by with its own charging cable that runs from a 120V outlet anyway. I was thinking of that kind of thing if we were to get a second short range EV, and was just planning to get its own 120V cord to plug in on the other side of the garage.
Oh the locking, that's a good point. I totally forgot that they all lock the charger. I'm not sure however on the home chargers, I assume they'll stay locked. The public chargers however unlock after charge and apparently anyone can stop your charging and unplug it. I'm hoping at home it's not like that. Time to dop some research, thx.The Leaf has an option to lock the charge port. So the adapter can’t be removed from the leaf and stolen. Not sure if the I3 has anything similar?
There isn't a "home" versus "public" difference on those. They are both J1772, and that is however it is. It's up to the car itself whether it has a mechanism to lock that handle in, and whether or not it uses the so-called "feature" of releasing the lock whenever charging is finished.Oh the locking, that's a good point. I totally forgot that they all lock the charger. I'm not sure however on the home chargers, I assume they'll stay locked. The public chargers however unlock after charge and apparently anyone can stop your charging and unplug it. I'm hoping at home it's not like that. Time to dop some research, thx.
Another excellent point which brings me back to my original issue. It doesn't matter if the car locks the charger when someone can just disconnect the Tesla wand from the adapter. I would say a few years back I would not even consider thinking the worse but the world is different now. I see the crazy crap in the surrounding neighborhoods these days and well that's the last thing I need is someone to do something jerky with the cars while it's charging.Leaf has -
- regular - unlocked
- auto - unlocks once charge finishes
- locked - locked all the time.
So I can safely use the adapter without it walking off.
of course it can be disconnected from the Tesla wand and stop the charging. And I’m not sure how graceful that happens? Will it break the control circuit first and avoid arcing?
To answer this part of the question, yes, this is handled (Ha!) in what the button press in the J1772 protocol does, which is also done by the Tesla button. When the button or release latch button are pressed while charging, that sends a signal to the car to interrupt the charging, so it cuts off in less than a second, so if you keep holding the button and pull the plug, it will not arc.of course it can be disconnected from the Tesla wand and stop the charging. And I’m not sure how graceful that happens? Will it break the control circuit first and avoid arcing?
Oh, I haven't seen one of those in person. I thought it also had a latch built into it. Yeah, if that connection is just pulled then, it probably will arc.Thanks @Rocky_H - I'm specifically asking if I separate the Tesla handle from the Tesla -> J1772 adapter. It can be done w/o using any button... For example when I drop the entire assembly too quickly or trip on the cord. It's just a pressure fit.
I’m not sure how to connect to the Tesla wand any differently (*). It’s a bit more robust with the latch and electronics in the car, but that means the adapter would need the latch and electronics too.Oh, I haven't seen one of those in person. I thought it also had a latch built into it. Yeah, if that connection is just pulled then, it probably will arc.
