car and driver P90D 11.1 @ 121 MPH
Discussion in 'Model S' started by fiksegts, Jan 29, 2016.
Tags:
  1. fiksegts
    fiksegts Active Member
    Miami
  2. shokunin
    shokunin P85 & M3
    Irvine, CA
    still disappointed we're not seeing 10's.. To trim weight, they opted for no pano roof, no 2nd charger, and no rear seats. Close, but no cigar.
  3. larmor
    larmor Active Member
    Irvine, CA
  4. Btr_ftw
    Btr_ftw Court Jester
    Mass
    with drag radials its a 10 second car easily. a 121mph trap speed is no joke, especially for a stock 4800lb sedan
  5. sorka
    sorka Well-Known Member
    Merced, CA
    While it's true it's traction limited up to 30 MPH, adding drag radials would only improve the time if the software allowed more power below below 30 MPH. As of this point, adding the wider 21" wheels doesn't improve the time over the 19" skinnier wheels so adding slicks won't do it either. But Tesla could and should add a drag radial mode. Also, adding more power at one one RPM will increase the torque at that RPM as well and the lower the RPM, the more torque the same power makes. Tesla may not be taking advantage of the 21" wheel traction as it is below 30 MPH because the extra torque may be beyond the design limit of the shafts and bearings or get to close to it for their reliability comfort.
  6. Btr_ftw
    Mass
    Traction limited, yes, however there is still a hint of wheelspin 0-30. If they can improve the 60foot by any means possible (cutting out that wheelspin), it will definitely shave some time up top
  7. qwertzy
    qwertzy Member
    Jamaica,NY
    Did they use the new launch mode? It doesn't really say.
  8. disillusioned
    disillusioned Member
    Phoenix, AZ
    To clarify, no rear-facing seats. Taking out the rear seats would be... impressive.
  9. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    The Model S rear seats (2nd row) are pretty heavy. If you have ever folded them down to access the trunk, you can feel how heavy they are. Must be a safety thing.
  10. fiksegts
    Miami
    no wheel spin at all in my car..... drag radials would not help....
  11. pedriscoll
    pedriscoll Active Member
    Indianapolis, Indiana
    Truly amazing. I have a "lowly" 85D and launching it still takes my breath away. My fastest 0-60 has been 4.0. I can't imagine what 2.8 feels like.
  12. P85DEE
    P85DEE Active Member
    TMC
    11.1 is impressive and said to be the average of 2 runs in opposite directions.
    Still not 10.9 but very impressive.
    I agree that drag radials would not help.
  13. Btr_ftw
    Mass
    I suppose your results may vary. The model S can spin its tires when launching according to other members.
  14. Iowa92x
    Iowa92x Member
    Iowa
    Turn off traction control, add drag radials, possibly that will take a tenth or two off.
  15. fiksegts
    Miami
    not at the drag strip, and who knows if they "corrected" the numbers....
    - - - Updated - - -
    it won't.... the car does not spin the tires, traction on or off... and launch mode does not work with traction off.. (slip start)
  16. sorka
    Merced, CA
    Agree about the drag strip. Until we start seeing real time slips from drag strips 11.1 didn't happen. They could just have easily corrected for ice factors like mt did.
  17. fiksegts
    Miami
    I think we have 3 P90Ds running on Sunday at StreetCarDrags.com
  18. cab
    cab Member
    Grapevine, TX
    Are the 19" rims any lighter AND if so AND if the traction was equivalent, that MAY have resulted in slightly quicker times (although not likely a full tenth). I think that same issue of C&D has an analysis of the new Mustang GT350's uber light carbon fiber rims on acceleration...pretty impressive delta between them and the regular rims.
  19. bhzmark
    bhzmark Supporting Member
    Yes 19 is lighter and therefore faster and better all around.
  20. jcaspar
    jcaspar Member
    Sacramento
    #20 jcaspar, Jan 30, 2016
    Crazy fast! Say good bye to the lowly Audi R8!
