11.33 @ 117 was my best run - P90DL at 86% SOC with 19" Cyclones/Michelin Primacy at 45 PSI.
I found this discussion as well from jak whom I had counted as one of the three I referred to earlier.
Sacramento Raceway, Wednesday 28 October, Let's TEST the newest software update
Back then he was reporting 11.4-11.5.
A few things stand out to me in comparing the 60ft times, the tires, the tire pressures, and at the reported states of charge.
19 inch Primacy tires, and at 45psi, at least from what is shown in the scanned time slips for this platform, have not yielded the 1.61x 60ft times necessary for 11.2.
Rather the best the slips showing 60ft times for that tire appear to be around 1.63x. And a 1.63x 60 seems to produce a best of 11.3 from viewing the available slips.
It has already been mentioned that much of this might be in the tires. I believe it. Looking at jaks slips at the 60s, it's clear that he was getting more tire spin than that seen in the 11.2 slips. Of course track prep could have contributed as well. But if you produce a 60ft time in the 1.63 range or worse, well then you probably won't break 11.3 in this car.
An 80-85% state of charge has not been reported where I can find, to produce anything better than an 11.3. That may or may not be the actual case; however when I look at the Vbox video from fiksgts 11.2, the car appears to be very close to a full charge. And he's running 40lbs of air and is not on 19in Primacy tires.
The passes later in the day, or the later passes for jak yielded higher ETs. Presumably as his SOC dropped toward 80%. By the time he makes his last pass an hour and 20 mins after his first, who knows what his SOC was, but it figures to have been lower than when he started. Even with a 1.63 60, at whatever SOC he was, the car can only muster an 11.4x by then.
All of of the cars had sunroofs.
So already we know a little about what configurations do not yield the best times.
It's this learning, not "additional power", nor "additional updates", which has resulted in the improvement we've seen from the first reported quarter mile results to these latest results. That was my point. And there is no denying that it is improvement.
For me, the subject matter of this thread centers primarily around the validity of the 11.1 time reported by C&D for a P90D with Ludicrous in the configuration and manner in which they ran it.
I believe their results are actual results, after seeing the results of owner cars in here, and that is of course more than I can say for the Motor Trend results.
