Car Automatically Turned On While I Was At Work
Discussion in 'Model S' started by 1ton, Jul 7, 2015.
Tags:
  1. 1ton
    1ton Member
    Florida
    Has this happened to anyone? My car was parked in the parking lot at work. I get an email that my car is "running". I looked on the app and see nothing wrong with the car. I go down to check on it and nothing is running. All seems good. I open the door and the music is blasting and I cannot turn it down. I had to reboot the screen. I wonder if the car just randomly turned on and so the music started blasting and that is what someone heard.
  2. Max*
    Max* Charging
    NoVa
    Do you have smart precondition on?
  3. AnOutsider
    AnOutsider S532 # XS27
    That's my thought as well
  4. Jhall118
    Jhall118 Member
    Seattle, WA
    The car is always "turned on". If it was making noise, it could have been a couple different things. I'm assuming it was hot, maybe the battery needed to cool, especially if it was charging. The 12v could have been getting a charge.
  5. 1ton
    1ton Member
    Florida
    What is smart precondition? It was raining so not as hot as normal. When I got into the car the volume was on 10 and AC was on HI. The screen was locked.
  6. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    I can't really use the "you probably fed it after midnight" since we probably all feed our cars after midnight.
    The smart precondition could explain the car being on, but it doesn't explain the radio being on. Now with that being said I have seen various reports of the slacker radio (or maybe it was something else) being on when it wasn't supposed to be. I don't know if that explains it. And it also doesn't explain the volume being at 10 unless the OP normally drives with her ears being blasted.
    It seems like in the OP's case the SW just glitched somehow.
  7. andrewket
    andrewket Well-Known Member
    Your car is possessed. Nobody will want it. But out of the kindness of my heart I'll buy it for $500. :)
    Most likely a software glitch.
    A
  8. scaesare
    scaesare Well-Known Member
    NoVA
    #8 scaesare, Jul 7, 2015
    What "emailed" you?
    On edit: this was from a person?
  9. Todd Burch
    Todd Burch Electron Pilot
    Smithfield, VA
    Regarding "running". Could've been smart preconditioning. Someone may have heard the clicking and fan noise that goes off periodically when the contactors for the main pack are engaged in order to charge the 12V battery, and thought the car was idling.
    Regarding music: when the car is waking up, if music is playing it can come on and start playing before the controls are responsive. So you sometimes get about 10 seconds of music playing before the controls are responsive to let you turn the volume down. The reboot may not have been necessary. You might have just been able to wait a few more seconds and you would have been able to pause the music or turn down the volume.
  10. 1ton
    1ton Member
    Florida
    The music volume was at 2 when I left the car. The GPS was also on and the address it picked was the work address I was at. I had not programmed that address in. The controls did not work. I was able to pause the music from the steering wheel. It was crazy. It also drained about 40 miles range from the car which leads me to believe that it was on for a few hours.
    The swrvice center is going to request a log.
    I had used keyless start from my phone and did not use my key fob to lock it. I am not sure if that could explain the car still running this draining the battery. The car knows to shut down.
    - - - Updated - - -
    Sorry, someone from the building at work emailed saying a Tesla parked in the parking lot was still running.
  11. Tdriver
    Tdriver Member
    Palm Desert, CA
    In the video business we had an expression for this scenario............"The electronics just got stupid". A reboot always fixed it.
  12. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I haven't had the music issue. But just this last Sunday, I walked into the garage at 3PM and the A/C was on full blast. Timing wasn't bad actually! But not anything that I had set. I just turned on preconditioning about 7 days ago. This was not a time when I would go to work. So...not trusting this SW yet. As with: lane departure, blind spot, collision avoidance or emergency braking. I have had so many falses that I have turned them off.
    Patience, my young padawan.
  13. Todd Burch
    Smithfield, VA
    40 miles? The A/C must've been on full blast almost all day for that kind of use.
  14. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    no. the a/c unit can use up to 8.5kW/hr. max A/C for just 2 hours will do it for sure. I've intentionally used this method to drain my battery to 0 miles fairly quickly while just sitting in my garage. that a/c and heat pump is a killer on range.
  15. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Is it possible that one of the doors was not closed all the way?
  16. Todd Burch
    Smithfield, VA
    I assume you had the doors or windows open? That's peak, which even on a hot day won't be sustained for that long if the doors/windows are shut, I'm thinking. But anyway, it's beside the point...I didn't do the math. My point was that the 40 mile loss wasn't just because the display was on, or due to vampire loss....the car was clearly using climate control.
    This posed a theory in my mind, since I believe Smart Preconditioning turns off climate control after 30 minutes (someone correct me if I'm wrong), and usage (especially for a "not as hot" day) wouldn't be 40 miles over a 30 minute span:
    There are scenarios with recent software versions in which walk-away locking doesn't engage. I've had it happen twice in which I've returned to the car and it's been unlocked. It seems to happen when you start to walk away from the car, the handles retract, and then you walk back to the car and open the door.
    I've had this happen once when I was parking at the airport and forgot something--went back to the car to get it, and after a week-long trip to Vegas found that my car was unlocked in the airport parking lot all week(!)
    Second time I was in a parking garage at a mall, but a similar scenario.
    Anyway, my theory is that walk-away locking didn't engage, and someone (perhaps the person who emailed you?) found the door unlocked. They cranked up the volume and climate control as a joke, then emailed you. (Or perhaps someone else did it to be nefarious or try to run down your battery, and the person who emailed was a "good samaritan".
    Anyway, it would explain everything. It's certainly possible.
  17. jct_4628
    jct_4628 Member
    Wisconsin
    Not a bad idea! People all over the place are interested in these cars and it wouldnt supprise me if someone bold tried the door and found it unlocked and then played with it. Maybe they saw someone coming and left the volume up and bolted?
  18. 1ton
    1ton Member
    Florida
    Todd, I agree with your theory of the walk away not engaging. The speaker and AC issue happened to me before. I called service and was told it's a software glitch and to reboot.
  19. CHG-ON
    I walk back and forth to my car (passing it mostly) all day long on the weekends and haven't seen it unlocked. But after reading this and having my A/C on for no real reason, I'll keep an eye out for this. I constantly forget things and have to turn around.
    Thanks for the insight guys.
  20. Todd Burch
    Smithfield, VA
    I haven't verified my theory with walk-away lock failure yet. I know a few others have seen it--but I haven't actually done any testing to explicitly try to reproduce.
