Got this 2013 MS P85 from the auction, no damages at all! clean carfax... but car was at 0% charge.
Boosted 12v from nose cone opened the car all is good till now, connected 12v battery to charger and connected the car to charge using mobile charger.
it took a couple of hours and I started to see some juice in the main pack...
next day I started the car all is good and I drove it for 5 minutes...
plugged it back on charger over the weekend when I came back to check the car it was maybe at 90% charge.
tried to run the car and got plenty of errors and the car is not moving now also would not charge if I open the charging port the lock pin is up and if I push it down it will turn red...
I checked with Tesla SC and they said main pack need to be replaced $30,000 Canadian dollars warranty ended 5 months ago!!!
I want to fix this myself! I appreciate every help or previous experiences.
mainly the fault is from BMS ...
BMS_f071 SM TransCon not met
BMS_w107 SW Cell Voltage sensor
BMS_w129 SW BMB VSH Connector
as you can see from the photos below, BMS status Fault, contractors open...
anyone knows what could be the root cause for these errors?
