ElectricAnt54
My tp-link TP-Link AC750 (TL-WR902AC) router was set to factory defaults. My pi Ethernet setup was default, never had to alter it. I use Tello data provider Which uses t-mobile. I Followed the instructions & it worked without issue.I sent this earlier to another TMC member:
"I did this sometime ago so not sure if I will miss any detail step but in general steps - With the router off - Turn router mode switch to "Shared ETH". Connect the USB Modem on the USB port. Connect the RPI Tesla Android ethernet port to the ethernet port on the router (cat5 or cat6 cable will either work). Turn Router on. Connect to the router through WiFi using your web browser from your computer (Windows, Mac, Linux, etc...) - there are two WiFi available networks you can choose to connect - both will work for configuring the router. Once connected to the router WiFi, login to the router through browser using address 192.168.0.1. Once logged in the router click on the "Operation Mode" tab and set the router as "3G/4G Router" and then "Save". Then click on the "Network" tab, make sure "Set the Dial Number, APN, Username and Password manually" is unchecked - if it is checked then uncheck it, and set Location "USA", and Mobile ISP "T-Mobile" (if you are using T-Mobile or any T-Mobile sub-vendor such as Tello, if not you will need to test for what works for your case) , the ISP details will be set automatically leave the APN as "epc.tmobile.com", set "Connection Mode" to "Always On", Set "Authentication Type" to "Auto" the click save. After successful save unplug power from router then re-plug power. Wait and it should start working. Make sure the blue light is not blinking , the first time you do this it takes a few minutes to get a solid usb modem blue light but the next time is fast. Login to Tesla Android, go to web browser and go to a "speed test" on a speed test web site of your choice."
