I KNOW this question has been asked before. I thought I knew the answer but I'm starting to question what I thought was "fact".
Does setting your Charge Limit have any impact on the amount of time it takes to charge at a Supercharger? If you set your Charge Limit to 100% will you remain at the maximum charge rate longer before tapering?
For instance, say you wanted to pull away from the Supercharger with 70%. Would it be quicker to set your Charge Limit to 100% and manually stop the charge at 70% or just set the Charge Limit to 70%? Is the point at which tapering begins dictated by the physical size of battery or software limitation imposed by the Charge Limit.
Thanks for clearing things up!
