Apart from the Anderson A2 pretty much all the home charge points out there are pretty ugly in my opinion and even if the charger itself is not too bad (EO mini is fairly subtle) if its tethered, then the cable and plug look messy. My charger needed to sit right on the front of my house and the aesthetics bothered me. I considered an Anderson but it would not fit my prefered location, a 35cm wide brick pillar. There is also the issue of the cost and the 3 month lead time so what to do......
In the end I put the charger (Rolec) inside my garage which is on the other side of the aforementioned pillar and brought the tethered cable through the wall to the outside but I still wasn't happy even with just the cable coiled up on the outside. So in the end i went custom and had a cabinet made for the cable. I'm pretty pleased with the result.
Obviously I only had the cable to worry about but there is no reason why you could not put something similar over the the whole charge point. This one is made from Aluminium. The only issue I can foresee with one that houses the entire charger is the possible blocking of the "smart" mobile signal, though some might consider that a plus .
