Apparently you didn't bother to click or read the link, where it says it is an adapter made and wired specifically for an EV/Tesla charging system, not like the normal camping adapters.
Oh sorry about that... Yeah, I can see this is a "special" adapter:
3750W max = ~120v x 30amps.
The description of the Amazon listing says "to 50-Amp" which could confuse some people expecting to pull 50-amps from that.
As has been mentioned before, "RV speak" includes calling all NEMA14-50 sockets as "50 amp" even if they aren't able to provide that current level.
They may have wired it so it is 120v across to two outside pins (which are usually 240V on a NEMA14-50. The Tesla UMC has a universal power supply that would adjust and I also think dial back the current based on it being 120V not 240V.
It says "electric vehicle use only" and I suspect that is important to follow. If you plugged some other NEMA14-50 device into that adapter it could try to draw much higher current and blow out the breaker on the TT-30 socket quickly.
It might also cause 240V equipment to act weird if it didn't have a universal power supply on it. So, yeah, only use that adapter as intended for a special case. I would call it a "hack", but it does serve a purpose.
Back to the comment that some RVs need/want/expect 240V from a 14-50 socket. I could imagine it is true, but they could then end up limiting their choices of camp sites. Many trailers and RVs I have seen just use 120V appliances inside and only use the 120V "neutral to leg" sections of the NEMA14-50. That way they can still operate if the camp site has only one leg hooked up, or both legs are from the same circuit so trying to pull from both legs gets you 0 volts.
Add to this that many old campgrounds, including lots and lots on the east coast, only provide TT-30 ("30 amp") and no NEMA 14-50 ("50 amp") so your 240V RV appliances would be SOL unless you ran your generator.
For that adapter, between the half voltage (120V not 240V) and partial current (30amp not 40+) your charge rate is going to be rather slow. But if it is for overnight camping maybe that is fine. I just wouldn't want to depend on that adapter for "while you wait" type road trip charging... Too slow.
