While Supercharging etiquette has been discussed here, I wanted to post a few rules that everyone should follow when using public chargers.
1) Don't charge to a high SoC on a fast charger like Chademo (with adapter) or Superchargers when others are waiting to charge. Speed slows down significantly after 80% and you could finish the last few % on Level 2 if you really need that extra charge.
2) Don't leave your car connected to a public charger after charging has finished. Don't be a jerk, orhers may need a charge too, so move your car when done.
3) Don't just park in a charging spot without plugging in for the same reason as 2)
4) Never unplug another car to plug in yours unless they have a sign that it's ok to do so.
5) Don't use public chargers like it's your personal home charger and leave your car all day plugged in unless of course there are plenty of EVSE's and you are not stopping others from getting a charge.
6) If the charger you are using is a single charger that is not networked, please check in and out on the plugshare app, so others know if it's available or not.
7) Generally, if you can, use plugshare for check ins or comments for example if chargers are working or if they have issues so others can avoid the charger if it's broken etc..
