Gotcha, so basically I'll run 230V over the 6-20 plug and the US-spec UMCv2 will ingest 230V over it? That would be kinda cool!First thing is that the plug adapters for the Mobile Connector don’t care about voltage. If you are actually in Europe, you should be able to buy a direct Mobile Connector Gen2 Schuko plug adapter. If you are un the US and want to use a European inverter to Charge your Tesla, just get a Schuko power cable and cut off the C13 connector or whatever is on the device end of the cable. You can buy a NEMA 6-15 or 6-20 receptacle that is designed to go on the end of a flexible cord. Then buy a Tesla Mobile Connector NEMA plug adapter to match. The important thing is that the NEMA adapter matches the inverter capability. For example if you have a 4kW inverter, you want to use a NEMA 6-20 adapter because it will allow 16A continuous and if your inverter outputs 230VAC that will be 3.68kW.
I found this product, I could probably just use this. Now, there is an additional problem I'm not sure how I would address, on US-spec 120V stuff thruout, when running off an inverter, I had to bind ground else the UMCv2 would not work — I guess I'd have to do the same for the 230V inverter?
I could of course get a split-phase inverter and hook up a 14-50 instead.. but like I said, the cost of those kind of inverters is considerably higher, and I've only got ~2.4kW of solar power to play with, even a 6-20 would give me almost 50% room to grow (which is not likely for the near-mid future). I will probably buffer some of the solar into a battery bank so I can charge at a faster rate when I am charging tho. If/when I build a big boy system I'll just put a WC in.
