Great stuff Mike, thanks again! Yeah getting the SoC and battery temp as close as possible would be ideal, but this is already a great start.
Would it be possible to overlay the relevant parts of graphs 1 and 3?
Ok, this is better - still not perfect with varying temps / SoC, though try this:
Slightly differing start and end speeds, though full data for transparency - SoC, bat Temp, etc for Insane on left, Ludi on right, dotted for Insane, translucent for Ludi again. mph on left vertical axis, rest on right axis
Ok, now to cheat a little - aligning on same starting speed (gives advantage to Insane a little) and aligning the time, then zooming in a little gives this:
Still searching for better aligned data at these speeds Marc, though hopefully gives a feel for the difference. There's obviously some squinting required... though I'm going cross-eyed already looking at all this data, so that likely helps me, lol.
- - - Updated - - -
p.s. Mike, did you ever weigh yourself and the car.
pss Interesting how slowly it seems the current falls when the TPS goes to 0--like .25 seconds its still full amps whle the foot is off the pedal.
No. Truck scales always seem to be closed when I pass one, and haven't prioritized finding one. Everything for me is relative - ie. I still have the same "stuff" in the back of my car for the last week+. I'm hopeful I haven't gained (or lost, yeah right) much weight personally in same time.
On second point, yea, makes me wonder if there's need for energy use ramp down going from full power to full regen. Though I would be speculating.
