omgwtfbyobbq
That's odd considering they are both front wheel drive. I have yet to see a car with a toe-out spec. Usually 0.00 to 0.15 deg. in.
FWD can get away with 0.00 because the wheels are pulled forward under load. I guess it could go either way though depending on front or rear mount steering rack. As far as gross amounts of movement, check out a Honda Civic (at least up to mid 2000s) doing a hard stop from 5 MPH. Probably an inch of movement in the wheel well, maybe more.
Edit: I stand corrected. Looks like 1984 specs -0.25 degree toe-out and 1985 is 0.00.
RWD usually specs a little more toe-in as the vehicle essentially "driving through" the front wheels, and they are following causing a small amount of toe-out under load. Mercedes requires the use of a spring-loaded toe bar that pushes the front wheels out during the alignment.
IIRC, smaller cars spec more toe-out because of the vehicle weight relative to passenger weight. 200-400lbs of people in the front seats of an 1800lb fwd vehicle will induce more deflection/toe-in than in a 2800lb fwd vehicle.
http://forums.vwvortex.com/showthread.php?4350264
