Based on the above and on Bjorn's video of a Model S 60 supercharging (
) I made the following table to compare both. From the translation it seemed the poster indicated actual charge going into the battery, so I took the same for the S instead of using the kilowatt power consumed (which includes cooling losses).
kWh added | Ampera-e power | [Ampera-e minutes | S power | S minutes |
+5 | 53 | 6 | 68 | 4 |
+10 | 53.7 | 11 | 66.5 | 9 |
+15 | 53.8 | 17 | 61.5 | 14 |
+20 | 54.6 | 22 | 56 | 19 |
+25 | 55.2 | 28 | 54 | 25 |
+30 | 55.5 | 33 | 51.1 | 31 |
+35 | 50 | 39 | 48 | 37 |
+40 | 37 | 47 | 43,3 | 44 |
+45 | 30 | 57 | 36,5 | 52 |
There is surprising little difference here. Especially when taking into account that an Ampera-e can actually driver longer with the same amount of kWh. Or maybe it isn't a surprise. In the end it is an engineering question. Assuming competent engineeering from both Tesla and LG Chem we'd expect similar results since their technological choices aren't that far apart. And that is exactly what we get.
To go from zero to half (+30kWh) takes 31 minutes on the S and 33 on the Ampera. But you get 14 miles more with that range on the Ampera-e. In reality that comes out as a wash. Beyond that, the Ampera-e tapers more aggresively making the difference at 45kWh added slightly over 5 minutes. (317 seconds according to my excel sheet). There the Tesla edges out slightly.
Obviously we don't know how the Model 3 (base model) supercharging compares with the Model S 60, but I can't imagine it being drastically different. The Model3 is a slightly smaller battery, which would put it at a disadvantage, but it's battery pack has seen 3 more years of development.
All in all, for European riders, when the Model 3 arrives, 100kWh chargers CCS should be out there. It may very well turn out that the suitability to (Northwestern) European road tripping will not primarily be a function of what the car can do, but how convenient your charging opportunities are. If you need to get off the highway and navigate a few red lights to get to your charging location, you may already have lost to the car that charged right at the exit. Same for if you have a charging opportunity every 50kms instead of every 100kms (making it more likely you can charge at optimal SOC).
Obviously the LR model 3 should blow both out of the water but it comes at a significant additional cost.
