SageBrush
REJECT Fascism
No doubt about it, today is really quite pathetic with few exceptions. But the idea is sound and cheap technical solutions exist to solve the problems you mention. Did you see the report of distributed charging implemented recently at a Cal-Tech garage ? VERY spiffy. Scale also helps solve the variable load issues grids currently face that result in high charging costs.Not when workplace charging costs the employee almost seven times what it does to charge at home, the way it does where I work. (9 cents vs 61 cents per kWh). Plus charging at work is a pain in the posterior because you have to move the car when the charging is finished and then try and find a parking space where your car won't get door dings (and when you're in the middle of a crisis, you can't move the car). Of course, if there were a large number of stalls with charging, that particular problem would be reduced, but as it is now, 500 employees, 2 charging stalls. This is basically greenwashing, not a commitment to sustainable transportation.
Now I understand some employers are far better than what I've described, but I'd guess the majority of large companies are more like the one I work for. And a small company won't do it at all unless the owner is into EVs, as some are.
