Clarity around CAC imbalances, voltage imbalances, bad bricks, and battery warranty - 2015 90D
Here are the non driving numbers.
Tesla says it's only 16% degraded
Hmm.. ur full rated on the other post shows 207mi
Depending on what rating u use, i get either 23% or 18% degradation (270mi or 253..)
Check out this thread:
8mV imbalance is really good.
This mornings 80% charge numbers.
So my 80% charge for the last 5 years (depending on the time of year and temp) 199-205, starting about actually dealing with this for about a year now. My 80% charge numbers range from 156-161. Plus when I bought the car it was already 1.5 year old, so I figured the normal degradation had already happen. So just take those numbers into play, its around 78% not taking into factor the first owners normal first year degradation.
I'd just like to know the nominal rating of the battery new so I can show them what it is now?
Are there any test/reading that I need to do? Full charge reading?
Also how do you all get the graphs that are attached to your other pictures to show historical data?
I think I signed up for teslafi years ago @hybridbear let me look.
62.6 kWh Nominal full pack is REALLY bad and probably going to fail soon. I would suggest "helping it" if you are still under warranty. For reference my 90 pack is 76.9 kWh with 83k miles.
@seenhear @hybridbear You need to go into the Google store settings and sign up for the "Join Beta" for this app to get the new visuals and CAC values.
Here is a Android screenshot of the beta version on my 3/2016 MS 90D.
@ajadan Let us know the specs of the new pack once you get it replaced under warranty 😁
How do you "help it" along to failure?
The SMT Beta has lots of issues. I had tried it before. Is it still unable to customize tabs like in the normal version? Until the customizing is there I won't change over. I only really use my customized tab with the values I want to see.
Also, I don't see CAC in your screenshot...
Reactions: seenhear
See post #4 and #12. Stress and heat, pretty much doing the opposite of what's good for a battery. 😇
It was in the app but cutoff on that screenshot. I tried to get it again just now but that field wouldn't populate. Like you said the beta app is a little buggy 😂
Reactions: cleverscreenam
Same experience here.
Yes, a drive plus leaving Phone connected for 20 minutes in car revealed a +/- 0,8% CAC imbalance on Model S 70D October [email protected]:
And total capacity of approx 221Ah * 3,6V * 6 Bricks * 14 Modules = 66,83kWh total to compare with 71,2kWh new
My usage pattern is charge as little and often as convenient and center around 40% SoC and all long resting should be < 55% SoC.(55% when NCA, 60% when NMC) .
As stated elsewhere the SMT BrickId is partly an integer and partly a Float and often way out of Range, say 111 on my 84 Brick battery :) I will report to SMT Beta.
