Something hit my headlight and there are hairline cracks near the top and bottom. I want some thin clear glue for them, I tried some 3M PR40 on the bottom but it turned cloudy when it dried, it's an Ethyl Cyanoacrylate glue. Any suggestions?
I tried a bunch of cyanoacrylate glues, they all turned cloudy in the cracks when dry, including Loctite Glass glue. Clear Gorilla Glue worked, different chemistry
CA will stick really well to the polycarbonate lens but will look terrible as you discovered. Gorilla is OK for that material but messy and won't really penetrate cracks.
I suggest windshield rock chip repair resin. It'll wick in nicely and will end up perfectly clear, inside the crack anyway. You can wick it in, then wipe it completely clean from the outside with isopropyl before starting the UV cure. It might not be strong enough to last very long but it'll look good while it lasts.
After using fillers/glue products on acrylic there is a need for a polishing in order to restore the original shine.
There are various procedures available for that, but there is no way you could glue acrylic material and then obtain a shiny, perfectly transparent surface.
Find many great new & used options and get the best deals for Tesla Model 3 Headlight Lens Replacement 2017-2023 LEFT Passengers Side at the best online prices at eBay! Free delivery for many products.
