I'm sort of stuck and not sure what to do..
Basically, my turn signal stalk is now clicky after I took it to a highly rated body shop for PPF. I suspect they must have pushed it down too hard and broke something inside.
It's like a stuck joint that eases the more you move it, but then when it's not moved for some time it becomes clicky again.
I'm super annoyed, especially since this body shop also broke the side camera clips and tried to hide that by gluing the camera back on. They've replaced the camera after I pointed it out to them, but I'm not sure if I can prove to them that this issue with the stalk is something they caused. I'm also not sure if I should go through the hassle of disassembling the whole unit to get it looked at - I feel like I'll get at least a couple of scratches or broken clips and whatnot.
Any advice will be appreciated.
