CyberGus
Not Just a Member
We are toast...
What if Elon starts outfitting the Starlink satellites with umbrellas
We are toast...
Since I got a thumb down to the quoted post I have the feeling that my position to have a neutral political point of view about the Climate Change issue has not been understood.The Climate Change issue has no political color so I refrain to say anything having political meaning, and I always refer to the Science.
This attitude of Governor DeSantis to deny the Science of the GHE and AGW is a serious lack of respect for people of Florida who have been hit by the recent floods IMHO.
I invite all TMC Members to watch the reported video by Greta Thunberg.Since I got a thumb down to the quoted post I have the feeling that my position to have a neutral political point of view about the Climate Change issue has not been understood.
So I wish to report this video by Greta Thunberg which better explains my view about the Climate Change issue.
Greta Thunberg: I have not come to offer any prepared remarks at this hearing.
I am instead attacching my testimony.
It is the IPCC Special Report on Global Warming of 1.5°Celsius.
The SR1.5 which was released on 8 October 2018.
I am submitting this report as my testimony because I DON'T WANT YOU TO LISTEN TO ME I WANT YOU TO LISTEN TO THE SCIENTISTS AND I WANT YOU TO UNITE BEHIND THE SCIENCE and I want you to take real action.
Chairman: Could you expand on why it is SO IMPORTANT TO LISTEN TO THE SCIENCE?
Greta Thunberg: Just such a thing that we should be taking for granted that we listen to the CURRENT BEST AVAILABLE UNITED SCIENCE. IT'S JUST SOMETHING THAT EVERYONE SHOULD DO. THIS IS NOT POLITICAL OPINIONS POLITICAL VIEWS OR MY OPINIONS THIS IS THE SCIENCE!
As usual you never know what the effects of GEOENGINEERING will be. It would be better to work out the Climate Change issue without using GEOENGINEERING, but I am afraid that sooner or later the consequences of the Climate Change issue will be so bad that we will be forced to use GEOENGINEERING.![]()
Climate engineering off US coast could increase heatwaves in Europe, study finds
Scientists call for regulation to stop regional use of marine cloud brightening having negative impact elsewherewww.theguardian.com
A geoengineering technique designed to reduce high temperatures in California could inadvertently intensify heatwaves in Europe, according to a study that models the unintended consequences of regional tinkering with a changing climate. The paper shows that targeted interventions to lower temperature in one area for one season might bring temporary benefits to some populations, but this has to be set against potentially negative side-effects in other parts of the world and shifting degrees of effectiveness over time. The authors of the study said the findings were “scary” because the world has few or no regulations in place to prevent regional applications of the technique, marine cloud brightening, which involves spraying reflective aerosols (usually in the form of sea salt or sea spray) into stratocumulus clouds over the ocean to reflect more solar radiation back into space.
The new paper suggests the consequences could be much further reaching and harder to predict. Published on Friday in Nature Climate Change, the authors claim to be the first to demonstrate that cloud brightening effects can diminish or reverse as climate conditions change due to the already dramatic human impacts of burning fossil fuels and forests.
In simulations of the more disrupted climate of 2050, however, the same two operations produced very different results because there were fewer clouds, higher base temperatures and a slowing of the Atlantic meridional overturning circulation (Amoc). Under these mid-century conditions, the operation near Alaska would have a drastically reduced effect on relieving heat stress in the western US, while the subtropical operation would push temperatures higher – the opposite of the desired result.
I have been hit by this pic of Italy. From some days we are having yellow sky over Italy. The massive Saharan dust transport from Africa reached the whole Italy as this Satellite image detected on June 20th.
In fact everybody here in Italy is complaining about this strange weather that we are having here in Italy. This is another aspect of the Climate Change issue which can cause stronger winds.
In fact you can store more moisture in a warmer atmosphere, so you can evaporate more. This means that the temperature difference between the surrounding air and the air that falls out of the thunderstorm is getting bigger, which causes a stronger downdraft and a stronger wind at the surface.
But the climate crisis has supercharged extreme conditions, setting the stage for new types of catastrophes that are increasing in both intensity and frequency.
