I’m a little surprised that you got an inverter with a screen. I had thought that they were only installing the non screen solar edge inverters now.
Oh? Any user-side implications with screen vs. non-screen?
You probably don't want my guess - just hope you get under the 4 months it took us. Did they say yet whether you can get the inspection done or whether they will have to submit updated plans to the county? If plans don't need to be updated, I think that could easily be a 6-8 week saving, based on my experience.Bets on how many weeks until PTO?
It all looks very nicely done.
Okay, here comes the photo post! So they did end up adjusting the layout, very similar to what you suggested @pdx_m3s . It's nice because moving the panels from the North-sides to the South-sides should net us an extra 0.5 MWh every year. Very pleased with how this turned out. Conduit hidden nicely behind the chimney (the extra J-box in the photo is from my Wall Connector). Got the optimizer map with serial numbers texted to me, just posting the numbered layout here so you can see how the panel layout changed.
That is good news on the permit. Since we had solar roof installed, it didn't change (but I think it did list 70 solar shingles on each face,) so wasn't certain about how much the county cared about that. The changes that caused us issues were more on the electrical side.The installers seemed confident it would go to county inspection next. My electrical permit just said "36 panels mounted flush to roof" so it's possible the permit doesn't mind the layout.
Also, I guess it wouldn't be a home project without something going wrong. Tesla called back to say they spotted some "CTs" installed upside down in the panel, so the electrician is coming back tomorrow.
And at least Tesla noticed the issue and is proactive about fixing it. Interesting that they noticed it after they left. Did you get a QA person to come by to inspect the work?
Just looked up what a CT is in this context. Evidently it's a Current Transformer and it's likely a part of the home consumption monitor: The importance of current transformers (CT) in today’s solar installs
So beside a master electrician looking at photos, it's also possible Tesla HQ saw the reading from the test run and the CT was reporting negative consumption.
Wow, I know there's been some discussion on these forums about solar panel impact on home insurance. We just updated our home description on USAA and their category "31-40 solar panels" added about $60,000 to our rebuild value
Only about $20 extra per month on premiums, though.
Also just got a call from Tesla, county permit inspection already scheduled for next week!
I wonder how much I can bug Pepco to speed up their end of the approval...
Good luck on PEPCO. Do you already have a smart meter? If so, after Tesla submits the Part II application, watch for the meter to reset to all 0's (and possibly flip back and forth to some sort of test mode.) If you don't get a notice about the net meter within the week timeline they promise, definitely check with them. This is where my notices stopped getting properly sent out.
I have the same kind. Essentially, one night the meter reset to all 0's and started flashing between that screen and some sort of Test screen. Also, when I looked at the green dot data, it showed an estimated reading for that hour (and charged me twenty-some cents, when it should be $0 since I was operating on PWs, but I was certainly not going to try and dispute.) Unless they sent an undercover technician at 1:00 AM, this was all handled remotely.Good question. What does a net-metering capable meter look like? Here's mine:
I don't think our meters show the kW number - just the kWh number. Unfortunately, since we don't cover our summer usage with solar, I never got to go below all 0's. But I did get satisfaction seeing the little cursors start moving right to left across the screen the first time, which is the indication that power is flowing into the grid instead of from it. It does move faster the more power, but no actual numbers.That looks similar to our meter and ours was capable of doing net metering. It is really neat to see a -xxxx kW displayed!
Our kWh number will go backwards, but since it started climbing during the month between reset and PTO, and since I don't offset, the numbers are still positive (and I don't know if it actually would go to -1 or all 9's.) Does your meter actually record kWh in and out as two numbers? We only ever get the combined amount.Ours is also kWh. Sorry for the error. But still it reads negative when you send power back into the grid.
