I've got an '18 LR RWD. Pretty much as soon as I bought it I got 19" turbines from EV Wheel direct. I've had two sets of tires - Bridgestone QuietTrack and Pirelli P7 AS Plus 3 (which are the quietest tires I have ever owned).
However, I have ALWAYS had a mild vibration at highway speeds that I can't get rid of, on both sets of tires. The vibration is mild, but if you look at a water bottle or the wheel you can see a very consistent rhythmic vibration while on a smooth road.
Here is what I have tried and results. I'll focus on the Pirellis since I've had them on for a year. Here is what I have done, in order:
Open to ideas. Thanks in advance.
- Multiple rotate and road force balance - has caused slight worsening or improvements but never eliminated (even on the Bridgestones)
- Index mount each tire to wheel to minimize deviations - all came within spec, resulted in improvement but not elimination
- New tire - discount tire was kind enough to replace the tire that was 'furthest' from zero index and did not result in any improvement
- Testing and straightening all wheels - Finally I decided the wheels must have been out of round from the factory (EVwheeldirect is now OOB but I am sure these are cheap cast alloys). I was actually in there when they did dismounted and tested. Two wheels were 35/1000" out of round, straightened to 20/1000. The remaining two were only 15/1000" out. So all wheels are now 15-20/1000" out of round which is within tolerance even for OEM wheels. This resulted in the most improvement to date, but not elimination.
