FlatSix911
Porsche 918 Hybrid
No issues with the shade installed.
How is the heat rejection... the surface does not appear very reflective?
Looks like you forgot to remove the packaging plastic from your dashcam. It'll prevent air flow from the vents and overheat.No issues with the shade installed.
Do you use cabin overheat protection? Using that should ease your mind and the heat shield will make it easier on the car to maintain temp below 104.Have you had any issues with the dash cam and heat in the summer? It gets to 110F+ where I live, meaning the interior probably gets up to 130F+ (if not hotter). I’m a bit concerned if I get a dash cam and put up the covercraft sun shade, it’s going to make that dash cam get extremely hot. It looks like they’re rated up to ~160F+ but I wouldn’t be surprised if the area between the windshield and sunshade got near those temperatures.
No issues whatsoever, but we don’t get temps that high here in the PNW, either.Have you had any issues with the dash cam and heat in the summer? It gets to 110F+ where I live, meaning the interior probably gets up to 130F+ (if not hotter). I’m a bit concerned if I get a dash cam and put up the covercraft sun shade, it’s going to make that dash cam get extremely hot. It looks like they’re rated up to ~160F+ but I wouldn’t be surprised if the area between the windshield and sunshade got near those temperatures.
On at least one test, the power drain was minimal compared to having AC fully on. However, that test wasn’t in extreme conditions like yours. I seem to remember that, like Sentry Mode, it will shut off once battery is down to 20%. You might try it when the drive home is reasonable and see what the drain is.I don't currently use it. The reason being is I think it would be constantly running trying to maintain 105-deg F causing excessive battery drain. I really wish we could set a higher temperature, like 130-deg, to prevent the interior from reaching really high temps (probably would just require the fans with no AC). I wouldn't be surprised if it's getting 150 F+ inside the car in the summer. I do have all my windows tinted (front windshield included) with SunTek CeramicIR tint and I use a Covercraft sun shield. This will be my first summer with the Model S so I'll have to give cabin overheat protection a try to see how much battery is actually used.
Cabin Overheat Protection doesn't run constantly. It comes on at 105° and runs until the cabin temp lowers to ~90° and then shuts off. Turns back on at 105° and repeats the cycle for 12 hours or until the battery gets below 20%.
Has anyone bought this one? https://www.covercraft.com/us/en/pr...stom-sunscreen.UVP?&zoi_id=1951588&sku=UVP-GS Vs this one https://www.covercraft.com/us/en/product/uvs100-custom-sunscreen.UV. I’d like to know what the difference is
