Cruise control denied
Discussion in 'Model S' started by SherSlick, Feb 15, 2015.
Tags:
  1. SherSlick
    SherSlick Member
    Denver, CO
    Has anyone else noticed the cruise control becomes "unavailable" when you unbuckle the drivers seatbelt? While understandable for a safety concern it was took my by surprise the other day.
    Never heard mention of this feature before either.
  2. marchyman
    marchyman Member
    San Mateo, Ca
    Mentioned several times under the general subject "TACC doesn't work" in the 6.1 release threads. Yup, it doesn't work when the seatbelt is unlatched.
  3. Majerus
    Majerus Member
    Illinois
    Overall pretty annoying, if you want to take off your coat or something you then have to use the pedal instead of letting the car offload some of the work making it less safe imo.
  4. Firewired
    Firewired Member
    San Antonio
    It may be there in anticipation of when the active steering goes into effect. Another way they could ensure the driver stays in the drivers seat is to use the seat sensor rather than the seatbelt sensor.
  5. GreenT
    GreenT Member
    Here
    Taking off your coat while driving cruise control speeds ... now that's less safe if you ask me! Or were you kidding?
  6. SherSlick
    SherSlick Member
    Denver, CO
    In the case of TACC it's less concerning IMO.
  7. donv
    donv Member
    Lake Jeanclia, OR
  8. eco5280
    eco5280 Member
    Country
  9. Majerus
    Majerus Member
    Illinois
    Nope not kidding, I drive 50 interstate miles to work in the middle of nowhere and taking my coat off with normal cruise control has never resulted in an issue. Now with this car disabling cruise makes it less safe as i have to manage a pedal as well. Also when the car can see traffic ahead then adjust its speed, warn me of leaving my lane, warn me of impending collision, taking of my seat belt for a minute is a risk I am willing to take with cruise on.
    - - - Updated - - -
    OK... so if tesla is protecting me from this level of stupidity I get it. However the car can sense weight on the seat and should disable the moment weight it gone..
  10. eco5280
    eco5280 Member
    Country
    Sorry, but I don't think a car company should design around you doing unsafe things you've frequently done for your convenience. Many people steer with their knees. It doesn't mean it's safe or that manufacturers should make allowances for it. I've taken my coat off many a time in the car too - and while I also can attest that I've never had something go wrong, I will freely admit it's an unsafe practice that could result in an accident, and that it would be 100% my fault.
  11. Majerus
    Majerus Member
    Illinois
    I agree anything that happens while I am driving is 100% my fault. However with the above logic why not force me to do the speed limit as well?
  12. Aljohn
    Aljohn Member
    Georgia
    Unfortunately everyone won't admit "it was 100% my fault". Some one will sue Tesla for allowing TACC enabled with no driver in the seat (weight missing), or no seat belt. I recall someone suing Coors for making their beer too tasteful.... thus made them an alcoholic.
  13. eco5280
    eco5280 Member
    Country
    @Majerus - there's no problem here. Either take your jacket off as you're entering the car, or pull off to the shoulder for ten seconds. Problem solved. And you're out what, ten seconds? Leave twenty seconds earlier and think of what you can do with all that extra time when you arrive at your destination :)
  14. deonb
    deonb Supporting Member
    Redmond, WA
    I hope not. Since relying on the seatbelt detector will only deter someone for 3 seconds until they figure out you just have to clip in the seatbelt before getting into the car in order to do this.
    Or maybe they figured that someone dumb enough to record this video, is too dumb to figure that out...
  15. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    I'm confused, the two or three times I took off my coat while in a car, I did not remove my seat belt. That said, I agree that one should just pull over or do it at a red light quickly if they do not want to do it outside the car.
  16. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    What is shown in that video is truly stupid and astonishingly reckless behavior, to climb out of the driver's seat while the car is in motion and on active cruise control with lane control engaged.
    I totally agree with Tesla's decision to require a certain amount of weight being sensed in the driver's seat for TACC or any auto driving functions to be functional.
  17. Thud
    Thud Member
    Atlanta
    Seriously, it makes no sense, especially when the self-steering is activated later on.
    If you can't crawl into the back seat and take a nap while the car drives down the highway, what's the point? :rolleyes:
  18. Majerus
    Majerus Member
    Illinois
    The car does not require weight to be in the seat, only the seat belt to be fastened. I tested it this morning.
  19. green1
    green1 Active Member
    Calgary, Alberta, Canada
    While I strongly believe that everyone should wear their seatbelt at all times, it sounds to me as if Tesla chose the wrong sensor here. If people realize this they'll just do the seatbelt up behind their back and continue to drive unsafely.
  20. eco5280
    eco5280 Member
    Country
    Same thing was said when govt required the seat belt ding. Instead, people started wearing their seat belts. Look at the rates go up and up and up since 1983: Seat belt use rates in the United States - Wikipedia, the free encyclopedia
