From what I can tell, there are two semi- or fully-blind spots on either side of the roof. I went out, and using the door control pop-up on the 17" as a guide, I held a board over different areas of the roof. Near the center, the roof-mounted proximity sensor seems to sense the obstacle fairly well, as would be expected. As I began to pull the board off-center, it quickly lost its reading (again, according to the simplistic readout on the 17"). Since, as far as I could test, there is only that single rooftop sensor and the door side sensors, the "blind spot" is anything generally above the windows of the FWD to the outside of the articulating hinge. This is corroborated by the three different intercepts noted in this thread.
The danger zones taper as distance increases from the roof and from the top of the articulating hinge. The roof mounted sensor seems to detect in a conical (or other nonlinear shape). And as the door sides begin to turn horizontal, the internal sensors become active to overhead surroundings.
My guesstimate of the "danger zones" are the areas enclosed in red.
