Today was indeed a consolidation day. What started out as a negative consolidation turned into a slightly positive consolidation, and then news came of a fed concern about when the economy will perk up and a Speaker Ryan statement that the White House and Congress are farther apart on tax changes than they were on health care. The net result was a drop in the broader markets and an exaggerated drop for TSLA as investors took profits, fearing a bigger drop.
One must now ask the question: Was yesterday the top of a big run up that is over and we return to the historical trading range (as shorts believe), or was today a normally volatile trading day for TSLA as it consolidates before heading much higher this year (as many longs believe)? The approaching Model 3 ramp up, the Tencent investment in TSLA, and the good Q1 delivery numbers all suggest a move to a higher trading range. If you are in the bullish long camp, then you will likely look at dips as buying opportunities for the big run up ahead this year. Shorts may feel emboldened from the run up so that they try to double-down at opening tomorrow morning and see if they can depress the stock further. Watch the short numbers tomorrow morning. It's also a tempting opportunity to cover for shorts who missed the chance earlier, so the net shorting activity is no certainty for the morning. Fidelity has been rationing the available shares to short in recent months, marking a fundamental change to the power of the shorts to manipulate the stock, and this change should also be taken into consideration.
Taking a look at the technical chart, you can see the upper bollinger band at 301.23 and TSLA at 295, which gives the stock plenty of room to run upward tomorrow if the market turns bullish again on TSLA. My guess is that we will see TSLA running below the upper bb for the most part in the coming months but poking above it when good news comes forth. Runs above the upper bb will seldom exceed two days, but once shorts start covering in numbers, that prediction goes out the window. Overall the upper bb is still relevant in TSLA trading, as we saw today even before the afternoon dip.
Conditions:
* Dow down 41 (0.20%)
* NASDAQ down 34 (0.58%)
* TSLA 295.00, down 8.70 (2.86%)
* TSLA volume 7.7M shares
* Oil 50.87, down 0.16 (0.31%)
* Morning's Fidelity short share drawdown or (covering) and interest rate: 193,000 drawdown, 1.00% interest
