Tesla made all service manuals free to the public. Search for what you wish to remove, and follow directions to remove.Do you have instructions to share on how to remove these pieces?
Are you sure it's from dash area. I had similar sound but I finally tracked it to the brake pedal rattle. There's a clevis pin which rattles on bad roads. Try to pull on brake pedal with your foot while driving on bad roads and if you can't hear any rattling sound it's your brake pedal. Easy fix by SC or you can just regrease the pin with lithium greaseMy Dash Rattle is coming behind the steering wheel ( dash board area ) not the wooden trim part. Any fix to this ill be grateful because its making me wanna sell my car. Took it to service and they couldn't fix it and the tech I did the test drive with said that taking apart the dash completely could bring other issues which I agree, just sucks
Had this brake pedal issue and had the entire assembly replaced , rattle is definitely coming from the dash because when I tap it I can hear a buzzingAre you sure it's from dash area. I had similar sound but I finally tracked it to the brake pedal rattle. There's a clevis pin which rattles on bad roads. Try to pull on brake pedal with your foot while driving on bad roads and if you can't hear any rattling sound it's your brake pedal. Easy fix by SC or you can just regrease the pin with lithium grease
I had a rattle in the front of my dash. Turns out it was the cover under the hood over the HEPA filter. Most of the plastic clips weren’t seated.My Dash Rattle is coming behind the steering wheel ( dash board area ) not the wooden trim part. Any fix to this I’ll be grateful because it’s making me wanna sell my car. Took it to service and they couldn't fix it and the tech I did the test drive with said that taking apart the dash completely could bring other issues which I agree, just sucks
yeah my issues is the actual Dash, when tapping on it there is a notable vibration rattle. Sticking some foam under the vent helps but it looks terrible.I had a rattle in the front of my dash. Turns out it was the cover under the hood over the HEPA filter. Most of the plastic clips weren’t seated.
I pulled off the piece of the dash with the wood on it. It rattled a lot throughout. Ended up using a lot of hot glue to get it to hold better together.yeah my issues is the actual Dash, when tapping on it there is a notable vibration rattle. Sticking some foam under the vent helps but it looks terrible.
yup looked at the wooden trim put felt tape down checked the vin plate, its 100% coming from the top dash, when i tap on it its reproducible every time. It really kills the driving experience to be honest maybe i might just have them take the dash apart at this pointI pulled off the piece of the dash with the wood on it. It rattled a lot throughout. Ended up using a lot of hot glue to get it to hold better together.
The piece was a lot bigger than I thought. It’s not just the wood piece, but the vent behind it as well.
There are also known issues with the VIN plate rattling, in case that’s what you’re hearing.
I feel your pain. Good luck!yup looked at the wooden trim put felt tape down checked the vin plate, its 100% coming from the top dash, when i tap on it its reproducible every time. It really kills the driving experience to be honest maybe i might just have them take the dash apart at this point
