This is awesome, can't wait to test this out. Now I need a bigger USB drive.
Tesla's built-in dashcam gets updated with side camera recording capabilities
My understanding is that hardware requirements are the same as for the Dashcam, as this is part of the Sentry Mode rollout (in the US anyway).Hmmm, I had not heard this yet. I wonder if it is also going only to cars with version 2.5 firmware like the original dash cam. If so, it sure rules out a lot of cars mostly before 2018.
What version are you on? Its been a long time since I had a corruption issue, and I assumed a firmware fix had corrected it. I still have the same usb stick that was getting corrupted, and its been at least 2 months I would say since I've had an issue with corruption. I'm on 2018.50.6 btw.If only I could get my dash cam to work, always gets corrupted
How are you still on 44.2? I assume you have your 3 connected to Wifi at home. Maybe signal range issue?44.2 still. No corruption issues with a new Kingston USB drive. Better question is... when will I get an update notification?
You may have tried this, but try removing your wifi connection from your car and then re-add it. I had issues with my car seeing my wifi, but once I tried reconnecting, its been solid.¯\_(ツ)_/¯ - yo no se! Had it on wifi for 8.5 hours last night. Nothing.
You should probably email your local service centre and see if they can remotely push the latest firmware to you.¯\_(ツ)_/¯ - yo no se! Had it on wifi for 8.5 hours last night. Nothing.
Damn @5_+JqckQttqck its almost like you are driving a stone age relic on 44.2Maybe I'm being held back for testing purposes o.0?
Yes on 50.6.What version are you on? Its been a long time since I had a corruption issue, and I assumed a firmware fix had corrected it. I still have the same usb stick that was getting corrupted, and its been at least 2 months I would say since I've had an issue with corruption. I'm on 2018.50.6 btw.
Yes on 50.6.
I just got a new thumb drive from work, will try it out again, formatted FAT32.
It always seems to record at first, but then when I park and return to car I get the small x on the camera icon
Ok good to know, I thought this was just me...it bothers me when it does this.I kind of like this version of AP. It doesn't reduce the Max Speed variable to the Current Speed variable if for whatever reason you take over from AP using the steering wheel while keeping speed control engage.
In the rental, the Max Speed (speed inside the blue circle) instantly becomes the Current Speed and stays that way. A few times I could of been rear ended if I didn't speed up manually.
I noticed on the latest update (2019.5.15), Max speed is maintained when taking over Autosteer, no longer dropping down and setting to your current speed. Finally fixed.I kind of like this version of AP. It doesn't reduce the Max Speed variable to the Current Speed variable if for whatever reason you take over from AP using the steering wheel while keeping speed control engage.
