A question about that spring... will you still be able to open the frunk if there is anything weighing down the lid? Like snow or ice, for example. I haven't got my model 3 yet, so I have no first hand experience with the latch mechanism. Sounds like a great idea if this is not a real problem!Things I would recommend are:
<snip>
<snip>
- Lower force extension spring for the frunk latch, so you can close the frunk one-handed without flexing the hood. I used one with a 1.4mm wire/15mm outer diameter/55mm length ($2)
I don't believe it will affect opening the frunk, but I did the spring replacement after the last time there was a lot of snow/ice on the ground. This is where I got the spring from: https://www.ebay.com/itm/1-4mm-Wire-Diameter-Expansion-Springs-Tension-Spring-Extension-OD-7mm-16mm/163115417648A question about that spring... will you still be able to open the frunk if there is anything weighing down the lid? Like snow or ice, for example. I haven't got my model 3 yet, so I have no first hand experience with the latch mechanism. Sounds like a great idea if this is not a real problem!
oh yeah - i forgot to mention that i also ordered
- wireless charging
- usb hub
both from jeda ..
i plan to buy a 500GB ssd drive soon for music + sentry mode
Accessories ordered for Day 1 already:
Trunk Organizer with handles (For bottom compartment)
https://www.amazon.com/gp/product/B07MXH28DS
Me too. Did you get the spacer?
The hub is backordered for a few weeks, so I placed two separate orders as they don't ship until order is complete. I wanted the charging mat ASAP.
Hi All, what about
Tesla Charger Adapter SAE J1772 Model 3 X S
? the converter to charge on other charging stations in case you cant make it supcharger.
I actually did not know that . So does this adapter come with car ?? ( oh paid 95!! For it )I was just about to post similar.
You do know the car comes with an adapter? Even so, I am considering getting another one. We have a Clipper Creek EVSE (J1772), so the adapter will be needed. When out and about, there are many places that we frequent that have free EV charging. We could just keep the adapter in the car, but it would be a lot easier if we could keep it permanently attached to the Clipper Creek.
I'm surprised that I haven't seen more posts mentioning the home Wall Connector as a day 1 accessory. I'm planning on putting in the Tesla Wall Connector with a 100 amp circuit because in rural Iowa there are definitely no Superchargers. It also seems that a set of snow tires or at least a set of chains may be a prudent investment. Although I was thinking they might not be needed with AWD.
