MassModel3, post pictures, I'm curious what it looks like. Also, if you can, provide some details about it, materials, design, etc. if you can.
This post is going to be off-topic, but since I was asked I wanted to provide an answer.
This project started because my wife wanted the parcel shelf and I didn't want to pay $250 for one. So, about $125 later....
I first learned that there are two primary types of sound suppression foam. There's the spongey stuff that you see in recording studios that's used to keep reflected sound minimized. And there's foam that's designed to minimize sound waves passing through it. This second type is what I used (
link). It's not terribly expensive, but it's heavy. According to the website, the stuff I ordered was 1/8-inch thick and 1 pound per square foot. I think what they sold me was a little thicker (maybe 3/16-inch) and therefore a bit heavier. Yes, a roll of this stuff was HEAVY (I order 5 feet, they gave me about 7). They also told me they have yet to find an adhesive that sticks well to this foam, so I had to change my design plan slightly in that I now needed to put it on top of the plywood instead of on the bottom.
To begin with, I created a pattern for the proper fit. I had to wait until I had a loaner, then I used the parcel shelf from that car to trace out the size of both sections (on each side of the 'hinge').
I used 3/8-inch plywood and cut out the proper shapes using a jigsaw. The curved edge I sanded smooth and rounded it. The MLV foam cut easily with a razor. At the hinge section, I beveled the foam's edges so it didn't impede folding the shelf up. For aesthetics, I also beveled the foam's edge over the rounded shelf section. Now I had the 2 foam sections and 2 wood sections ready for assembly.
I glued the 3 long straight edges of the plywood pieces into aluminum trim channels for extra support. Next, I spread construction adhesive across the top of the plywood and laid my MLV foam on top. I used 1/2-inch wood screws (probably lots more than I needed) to permanently affix the foam to the plywood. The screws sank into the foam and were almost flush (bonus!). Over the aluminum tracks, I drilled several holes through the foam, into the aluminum track, and into the plywood. I then screwed the foam into the aluminum to ensure flat edges.
I used the denim legs of an old pair of jeans to create the hinge, which I glued down with construction adhesive. First I glued a hinge across the top with the two boards together (a small spacer of folded denim between the boards to create a small gap for the rest of the hinge), then once that dried I folded the shelf in half and glued another hinge across the flat areas (this filled the gap). On both top and bottom hinge areas, I extended the denim about 2 inches over the wood to ensure permanence. I also used denim to wrap the rear flat edge over the aluminum, just to give it a smoother feel and help protect the car.
Next, I cut the 1/2-inch cotton batting slightly larger than it needed to be to covert he entire shelf in a single piece. I sprayed the top of the MLV foam with the LocTite and stuck the batting on, then wrapped the batting tightly around the edges and glued it down to the wood on the bottom, making sure to cut it away from the hinge area.
I'm not sure the fabric I used -- maybe nylon. Black, shiny, and slightly stretchy. I just liked the look and feel of it. I wrapped the top of the batting and used a staple gun to fasten it to the bottom of the plywood. I left the fabric free floating on the batting.
Last step was just a cheap carpet runner from the local discount store that I glued on the bottom using heavy duty construction adhesive.
The completed project weighs in at a hefty 25 pounds, but I can definitely tell that the pitch inside the car is lower and it
seems quieter to me. And my wife is happy she has her parcel shelf. Win/win.
