hi - i noticed that my roadster (2.0 s) stopped charging and i'm getting the above mentioned fault. the outlet is fine as i use it to charge our X (50 amp). i get same results on the roadster using the 240 cable as well as the 110 cable on different outlets. the battery is cold with about 144 range miles on it. when i plug it in, the display says it's warming battery and it's zero % complete and charge port is blinking blue and then it changes to blinking red.
any suggestions?
any suggestions?
