Coming from Turbo ICE's car, going WOT with a cold engine / cold oil is a big no-no.
Do i need to drive for a couple of miles before opening the car up?
For maximum current flow out of the battery to the motors, they have to be warm. Same for super charging, high current flowing in (to the battery) from the opposite direction.
I don't Supercharge that often, but I finally saw that "Preconditioning battery for supercharging" message today...
You were probably routing to a Supercharger with the cars navigation system which does that automatically to prepare the battery. Preconditioning warms the battery to a fairly warm degree (i.e i've seen it precondition on a hot day) but isn't absolutely necessary, it just means faster charge times (again being restricted by software)
Correct, but the driver does not need to treat the car any different than normal. It will limit itself via software, so you can go crazy with your driving.
Or rented itDrive it like you stole it.
It isn't the motor. It's the inverter which is located in the motor assembly. The motor does not need to be warmed but as it is doubtless on the same coolant loop as the inverter it will get warmed too.pre warming the battery is a good idea especially if it's cold out. On a model 3 at least the motor is used to
warm the battery so you can warm them at the same time.
Or rented it
If the battery is too cold there's a little snowflake icon that shows up on the screen. I assume if that's not there you are free to drive the piss out of it and it will act accordingly.
